Question about Radio Shack Pro-82 Scanner
Locked out! All channels Locked out! How do I unlock the channels, I don't know how I locked them out. I tried the instructions in the book and I am still locked out. HELP!
  • 1 more comment
  • jplandry Jan 24, 2008
    I have the same problem. The scanner won't scan because all the channels show locked out. They are also set to 000.0000. It's like the CPU didn't completely initialize the hardware ( I'm a firmware guy )
  • Sam Mar 09, 2009
    Hi Ok I have the same problem the scanner wont reset gives me 0000 read out and the L/O is on cant get it off all keys are loched so you cant put in a FREQ HELP!!!!!!!
  • scachfd542 Apr 10, 2009
    how can i lock out a frequency that i dont want anymore on my scanner??/
    Problem Solver:
  • 13 Answers
Turn off the scanner and hold in the reset button and then turn it back on.
Posted on Aug 24, 2007
Press and hols down the "LOCK" for three seconds
Posted on Aug 17, 2007
    Problem Solver:
  • 12 Answers
Go to the channel that is locked out and push the l/o button above the light/lock key. it should unlock the frequncy so that it will scan through . but you have to do this with every frequency thats locked out. if it says 000.000 then you have to program it, and then the l/o will be gone
Posted on Feb 06, 2009
SOURCE:
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Don,t know code for simlock
There are two types of Sim lock ,
1. Sim locked to Network
2.Sim locked with security code,
if the Phone locked to Network means get the Unlock code from here
Superunlockcodes and get the Free unlocking instruction from here
Mobileunlockguide and Unlock it...
If it locked to security code means get the master reset code from service provider reset it.
Jul 09, 2011 | Health & Beauty
Re sanyo 68cm stereo tv model no. cp29ys2
Hold the button directly under the AV1/Av2 select button for 2seconds..this should unlock..see manal page 12..not 13 like the error list states
Oct 16, 2008 | Televison & Video
Locked out!
press c for a long period of time
Apr 27, 2008 | Radio Communications
Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
[email protected]
[email protected]
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Chanels locked
Page 49 of the instruction book tell you how to reset the parental codes. You can go to www.jvc.com to download the instruction book. Or call the customer support number listed on the site.
Nov 14, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Radio Shack Pro-82 Scanner Logo
440 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
