Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Red Tint on Hitachi 51F510
There is a permanent red tint (haze) over the center (4:3 aspect ratio area) of my Hitachi 51F510 screen. I mainly notice it when watching HD channels since the edge of the tint lies where the edge of the side bars normally are when watching SD channels. Any help/advice would be appraciated.
  • buzz1857 May 04, 2008
    I have the same model TV. It definately has image burn. The TV was left on and the picture froze. I now have CNN burnt on my screen. I purchased an extended warranty with the TV at Future Shop but apparantly it covers just abount any problem but mine.
    Is there any way to repair this and how much might it cost.
    Gord
  • BUbobby24 Feb 18, 2009
    TV has a red tint to it.
    Sergeant:
    Champion:
  • 375 Answers
Sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Posted on Apr 13, 2008
SOURCE:
Blue or red tint netbook screen
Yes! unfortunatelly all the critical circuitry is built in behind the LCD display making the screen replacement manditory.
Apr 15, 2012 | Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
My Hitachi 51f510 projection tv just started to have a problem with the color. It appears that the tint is red/pink and I have no control over it.
For me to help you (I think I know what is wrong and it is fairly simple to correct) I need to ASK you something.
If you turn the color all the way to zero and go to a channel that is in black and white, what color is the screen?
If it is red or redish a simple adjustment will correct this problem.
Is the picture with color down to zero on a black and white channel (old movies) red looking?
Before you rate this information, let me know what you find. I am in California and will be available for a while.
SD TECH
Jul 15, 2011 | Hitachi 51F510 51" Rear Projection...
I have a Hitachi 55VS69A television. I replaced the bulb and not long after I did that I had a blue haze in the center of my screen. The blue haze spread to the right hand side of the screen, and now...
I have a Hitachi Ultravision. 55VS69A. It has worked wonders but now there is a blue screen in the center of the tv. Should I just replace the bulb. thank you.
alex
Apr 19, 2010 | Hitachi 55VS69 55" Projection HDTV
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Diffenent tint to 4:3 area during full screen projection.
di you try to conv. it and if that don,t work you need to see a tv repear
shop
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
Our hitachi 50c20 is overheating and turning off. It also has a red tint on whole screen when playing. We replaced the bulb but still the same. It is located in a well ventilated area.
i dont know about the overheating problem, but as far as the red tint goes, it you go to the picture setting within the menu and reset it to default, it should take care of that.
Jul 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi ultravision 50 inch lcd 50v500a
A BIG RED SPOT APPEARS ON THE SCREEN WHEN U TURN IT ON WHEN IT IS STILL BLACK. THEN ARED HAZE IS VISABLE IN ABOUT I 6 INCH AREA WHEN VIEWING THE TV.
Nov 25, 2007 | Televison & Video
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
426 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
