Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100L -
Hey... I've had a few ongoing issues with my TV which is less than 4 years old. First I occasionally got a pop up on the TV saying I had to go through the initial set up process and auto program. I though this may be because of dead batteries in the remote, but after changing them, the problem persisted. About a week ago my remote went completely dead - not a battery issue, but when I turned the TV on from the TV itself, all was fine. Yesterday I tried to turn on the TV, and the standby light was flashing. I couldn't get a picture, and the TV just scrolled through Video 1, Video 2, Video 3, and Video 4. When I tried to use panel on the TV, nothing worked. Every button on the TV (volume, channel, setup, menu) would not function as normal - it would only scroll through the different Video 1, 2, 3, 4... What's up???
    New Friend:
  • 76 Answers
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Posted on Sep 06, 2007
How do u turn on a Sony Trinitron kv-27FS100L when it is on standby timer with 4 blinking code
remove power for five min. then reconnect and push power button in for 15/ 30 sec
Dec 13, 2016 | Sony Televison & Video
Need Comcast remote code for sony trinitron KV27FS100L
These are the codes to check. 10000, 10011, 10273, 10353, 10834, 11317, 11400, 11685, 11786, 11791, 11904, 11925
Sep 15, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My sony tv kv-14Af1 horizontal output got shorted
if it gets taken out in less than a minute or instantly you may have a cap in the horizontal driver circuit way down in value or open kvf1 is not a good model number in the Sony data base--year and model will be on back of set--KV says it is a direct view or crt type set.
Can you check and confirm the model number?
Apr 01, 2012 | Televison & Video
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
