Question about Garmin StreetPilot C330 GPS Receiver
C330 does not work
I left the GPS in the car in very hot weaher. I think I cooked the battery but I do not find a way to get inside to check the status of the battery. After trying to get the GPS turned on so it would charge the battery, the fuse not is burned out. Wil I have to send the GPS to a repair facility? Is there a way that I can open up the GPS to replace thebattery? Harry E Hubbert Phone 941 773 4426 (Cell)
  • 69 Answers
I wouldn't suggest opening your unit, the garmin manual says that once the unit is opened your warranty is void. Have you tried resetting the unit? Here is how you do that:
Posted on Aug 26, 2007
  • Anonymous Aug 26, 2007
    Otherwise you may want to go thorugh this process:
    STEP 1: Contact Garmin Technical Support to receive an RMA number.
    Call or e-mail Garmin Technical Support Specialists to describe the problem you are experiencing and request a Return Material Authorization (RMA) tracking number. You will need to provide the unit's serial number (if applicable), your return shipping address, and a daytime telephone number.
    ***Aviation Panel Mount or Aviation Remote Mount products require an authorized person to return the aircraft system to service after product repair. Please arrange RMA's through your favorite Authorized Garmin Aviation Service Center.***
    Phone: 1-800-800-1020
    913-397-8200
    Fax: 913-397-0836
    E-mail: Tech Support
    For Garmin AT products only:
    Phone: 1-800-525-6726 (U.S.)
    1-800-654-3415 (Canada)
    503-391-3411
    Fax: 503-364-2138
    STEP 2: Ship the unit, along with the RMA number, to Garmin.
    Once you have received the RMA number, securely package the unit and ship it (insured) to the following address:
    Garmin International
    1200 E. 151st Street
    RMA Number: (insert your RMA number here - see above)
    Dock Door #1
    Olathe, KS 66062 USA
    Garmin AT, Inc.
    2345 Turner Rd. SE
    Salem, OR 97302
    Or find a local garmin repair center.
    Hope this helps:)
    Jason
SOURCE:
C330 will not power up when plugged into power receptacle in car
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+STREETPILOT+C330&Show=ExtInfo I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Jul 11, 2010 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps will does not work
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My navigon 2100 is frozen. how do i unfreeze it?
2 OPTIONS
Oct 25, 2008 | Garmin StreetPilot C330 GPS Receiver
My garmin gps will not charge and it will not stay on.
Your battery inside the GPS is most likely either defective, or has been overcharged, creating an effect where the dry cells inside the battery are swelled and no longer work as they are made to. The only way to fix this is to send the GPS to service and have a new battery installed. to avoid having this happen again, don't leave any device with a rechargeable battery plugged in longer than it needs to be(IE after it has fully charged).
Oct 07, 2008 | Garmin GPS
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
