It wont fill up and spanner light keeps coming on?
That is Error code 49
49.(00110001) Cold Valve Coil Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty. The most likely cause is that the valve harness has not been connected correctly or the valve is open circuit. See fault 48 for service procedure.
48. (00110000) Hot and Cold Valve Coil Faulty
The Motor Controller module has measured voltages from the valve diagnostic circuit that
indicate both the hot and cold valves are faulty. The most likely cause is that the valve harnesses have not been connected correctly or the valve is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves or the
pins are not bent backwards.
Secondary Source: Water Valves.
Action: Check the valve coils are not faulty (open circuit).
Tertiary Source: Motor Controller module.
Action: Replace the Motor Controller module.
Further information on my washing machine when I go to start a load ,it wont fill then about 5secs later beeps and the spanner,delicates,sheets & high efficiency lights all come on.
