Question about Pentax Optio W10 Digital Camera
Optio W10 usb cable does nothing
I have the usb set to PC I have installed ACDSee v6 which came with the camera. Camera is new. I plug the USB lead in. My computer does not detect anything. ACDSee does not detect anything. ACDSee icon in the task bar should be green when there is a camera detetected but it's green all the time whether the camera is plugged in or not. If I choose tools ACDSee Device Detector then only a baloon pops up saying click here to learn how to use this, and if I click on it it opens my browser then fails to load anything. Using Windows XP Pro. Tried the usb connection on another pc but nothing. Looks like the usb just doesn't work.
  • Ganto Dec 24, 2007
    I believe that I have the same problem. My USB cable used to work but I have not used it in a while. The one thing that is puzzling to me is that the camera will not power on when I have the cable attached. The camera powers of as soon as the battery/USB connection compartment is opened. I have tried connecting to a pictbridge compatible printer (Dell AIO 942) and get the same result. The camera will take pictures as I am able to remove the SD card and transfer those to the computer by inserting the card into the memory card reader on the dell printer. Is the supplied cable the only one that will work?
  • randy461 Dec 16, 2009
    How do I plug my usb cable into the camera
    Genius:
  • 2,985 Answers
The first rule with any new didital camers is as far as I am concerned is -Leave The Disk in The Box Windos is quite capable of reading removeable meadi with out extra layers of programs. So Remove the software [Start/Comtrol Panel/Add Remove software, etc., Reboot the computer. Plug in the camera Make sure it is set to the upload function[see manual] Windows Camera/scanner wizard will come up select what you want to do[coy to folder] click OK. Do all this first If still in trouble check the cable with another, and if you can remove media card and try through yours PC or another via a card reader. You have to eliminate which is dud Camera[switchng] cable. When you have make the decision and concluded it is the camera/cable, pack it all up and take it back from the place it came from.
Posted on Aug 25, 2007
6ya staff
SOURCE:
Pentax optio w80 driver
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 17, 2013 | Pentax Optio W80 Digital Camera
My computer does not detect my Pentax Optio w20 digital camera
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDsee or any other photo cataloging program.
Jun 09, 2012 | Pentax Optio W20 Digital Camera
Can't install the software to my pc.
You don't need to install anything.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as ACDSee.
Dec 16, 2011 | Pentax Optio W10 Digital Camera
I cannot install the software for the camera to my pc.
Optio E30 unable to download photos?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
Jun 02, 2009 | Pentax Optio E30 Digital Camera
Where can I get Free software to download pics from cam ptio w10
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Apr 10, 2009 | Pentax Optio W10 Digital Camera
Windows xp does not recognize optio s 4i
Mar 05, 2009 | Pentax Optio S4i Digital Camera
ACDsee software
here is the Pentax Optio S12 software:
http://www.freedriverload.com/all43095.html
Dec 29, 2008 | Aqua Pentax Optio S12 Digital Camera
PC Connection
i think it is bad connection from the usb cable to the camera try to move the connector in the camera( bending)
Jan 07, 2008 | Pentax Optio M20 Digital Camera
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Pentax Optio W10 Digital Camera Logo
124 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
