Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
HDMI module The hdmi quit working. The TV works fine through the components cables. I tried the hdmi cable on another tv and it worked fine. Where can I buy a hdmi module?
  • 2 more comments
  • Mack Deaton Aug 17, 2007
    Maybe I wasn't clear enough on my problem. The tv has been working fine on HDMI for 2 years. One day I turned it on and had no sound on HDMI, a few minutes later the picture went out. I checked my inputs and went to the menu and the HDMI is grayed out. The tv works fine in high definition through the component cables. I tried the HDMI cable on another tv and it is fine therefore I thought I needed a new HDMI module, I just don't know where to buy one. If there is something else I can do besides replace the HDMI module, please let me know.
    Thanks.
  • paisano Apr 30, 2008
    My Sagem Axium HD-L32 tv has suddenly stop recognising the signal from my Virgin V+ Box (cable tv). I am using a Monster HDMI cable and also two scart cables connected to my tv via a Samsung DVD-HR735 Recorder/player. Can you to re-start (kick-start) this conection again?
    Many thanks: Jay
  • Jakey1 Sep 07, 2008
    sagem axium HD L32 tv worked on high definition for one week then suddenly 'no signal' appeared on the screen and I cannot watch HD tv. I can watch TV through the v+ box on 'normal' tv settings. Cable engineer says the tv is faulty. Could there be another reason that the signal has gone?
  • Anonymous Dec 20, 2008
    I have a Panasonic TH-50PZ80U which is 2 months old. I have connect to the TV with a HDMI cable from my satellite box. Has worked fine but all of a sudden the TV had a "power off in three minutes" message. TV will produce no picture via HDMI cable but will through component cables. I have two HD satellite boxes and I've tried both neither will produce a picture via HDMI on this TV..
    Sergeant:
    Champion:
  • 375 Answers
Acess the service menu (power off then press mute 1-8-2-power) you should have a service bookfor your setting you might have the hdmi off.
Posted on Aug 18, 2007
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
I have a hitachi 42hds52 tv; i have my cable box connected to it by both hdmi and coax cable. the coax is fine, but the hdmi is not working
Try the anothe HDMI input or cable or try HDMI from another source (DVD) you could also try component in(Ry,Gy and By) to see if that works.you need first to determine if it's a cable box, cable or TV issue.
Oct 11, 2009 | Hitachi 61SWX10B 61" Rear Projection...
HDMI and Component Outputs do not work simultaneously
try using a digatal out cable instead of rca cables this should solve the problem!
Nov 06, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
279 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
