Question about Toshiba Satellite A135-S2276 Notebook
Memory Installation I don't have my owner's manual because I am out of the country...but, I need to install additional memory. How do I do it?
  • 32 Answers
Have you tried checking support.toshiba.com for the user's manual?
Posted on Oct 27, 2007
    President:
  • 2,961 Answers
It's a simple thing to do, it's a case of finding the correct bay that the memory resides in underneath your laptop. Remove a panel a time by removing the screws and remove the plastic cover panel and when you find the empty memory slot, you put the memory in at a 45 degree angle and then clip it in gently.
Posted on Aug 16, 2007
SOURCE:
How to add ram
open the panned which is located on the base of the laptop and just buy a ram use the model number listed in the catalog or you also check from toshiba website using the model number of your laptop.
there will be two slots in the laptop one which will have a RAM on it and the you will see the other slot which is empty so you just need to insert the RAM like the way previous ram is attached on it. and thats it you can turn on your lappy and u r good to go
Jul 24, 2014 | Toshiba Satellite Computers & Internet
Dell xps 200 installed new hard drive
I share information HDD back site small jumper available so you attach 1-2 and CD back side available jumper not connect any pin. Mother board auto find it and not any issue ok.
Thanks.
TechSupportMart Computer Support
Feb 14, 2014 | Dell Dimension 3000 PC Desktop
Computer beep codes
Installing Memory), and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • Installing Memory).
  • Memory Installation Guidelines).
  • Replacing the Battery).
  • If the problem persists, contact Dell.
  • 6
    Video BIOS Test Failure
    Contact Dell.
    7
    CPU cache test failure
    Contact Dell.
    Nov 11, 2013 | Dell Computers & Internet
    How do I upgrade the Ram. I don't know how to get to the memory slot.
    1. The first thing to do is make sure the computer is shut down.
    2. Please ensure that the power supply switch is turned off, you may leave the power supply plugged in while the switch is turned off to provide an active ground. However if your power supply does not have a switch then unplug the computer to make sure that it does not power on accidentally. Please discharge any static electricity by touching an unpainted metal surface before handling any computer components. Frying a chip with static electricity is a rare occurrence, but still possible.
    3. Remove the computer's cover following the instructions in the model-specific owner's manual.
    4. Locate the memory expansion sockets on the computer's motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
    5. Once you've discharged your static electricity, pick up the memory chip by its top or sides. Don't touch the silver or gold contacts at the bottom, because even a little oil from your finger can eventually interfere with the connection. Regardless of the type of memory you have, it will only go into the empty memory slot one way, so look at the notches in the contacts and line them up so the partitions in the RAM sockets fit in the grooves.
    6. Insert the module into an available expansion socket. Press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
    7. For most installations, DDR2 modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner's manual to determine the correct installation sequence for your configuration.
    8. Turn on the computer and follow the instructions in your computer owner's manual that describe the steps necessary to allow your computer to recognize the newly installed memory. (Most computers will automatically recognize the additional memory installed).
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 15, 2010 | Gateway eMachines EZ160101 PC Desktop
    How to install upgrade sdram 128 pc133 for gateway 500
    INSTALLATION PROCEDURE
    1. Place the computer's power switch in the "off " position and disconnect the AC power cord. 2. Remove the computer's top cover following the instructions in the model-specific owner's manual.
    3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
    5. Handle your new module's carefully; do not flex or bend the module(s). Always grasp the module by its edges.
    6. For some installations, DIMM memory can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner's manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. Repeat this procedure for any additional modules you are installing.
  • Most 168-pin DIMM modules have ejector tabs. The ejector tabs are used only when you need to remove a module. By pressing down on the ejector tabs, the module will pop-up from the socket and it can be removed.
    7. Once the modules have been installed, the computer's top cover can be reinstalled.
    8. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    9. Turn on the computer and follow the instructions in your computer owner's manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
    May 03, 2010 | Gateway Essential 500 PC Desktop
    Chrysler town and country Memory Seats
    Memory selector is on driver's door, First set driver 1 seat and mirror positions, then press and release memory "s" button. then press and release memory selector "1" button. repeat for # 2 driver substituting memory selector 2 in step 2. hope this will help you
    Jan 26, 2010 | 2000 Chrysler Town & Country
    How to install memory for T3642 eMachine
    eMachines T3642 Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 1.0 GB = 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T3642 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 1.0 GB = 512 MB (removable) + 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
    1. Place the computer power switch in the "off " position and disconnect the AC power cord.
    2. Remove the computer top cover following the instructions in the model-specific owner manual.
    4. Locate the memory expansion sockets on the computer motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
    5. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
    6. Handle your new module carefully; do not flex or bend the module. Always grasp the module by its edges.
    7. For most installations, DDR modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. install_ddr.gif 8. Once the module or modules have been installed, the computer top cover can be reinstalled.
    9. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    10. Turn on the computer and follow the instructions in your computer owner manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
  • I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
    Oct 23, 2009 | E-Machines eMachines T3830 PC Desktop
    Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
    You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. [email protected]
    Oct 08, 2009 | Sharp AR-M237 Digital Copier
    Gateway sb-4100-b won't recognize new memory
    Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
    Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
    Toshiba Satellite A135-S2276 Notebook Logo
    65 people viewed this question
    Top Toshiba Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
