I have a 2000 ford windstar. Recently a steady thumping started in the climate control vents. It sounds like its behind the center of the dash. It sounds like is a vent door opening and shutting over and over steady. I have got it to stop a couple of times by just sliding the temp from hot to cool. However, it still makes the noise even if I set the climate control to off position. Majority of the time it thumps in both temp positions and stops after about 10 to 20 minutes. Could this be a vacum hose problem since I just got an oil change and filters changed? I looked but did find anything obvious. Can you help?
On my 2000 Windstar, I had this same problem. I replaced the vent door motor and the problem went away. It is roughly $40 from O'Reilly. The motor is a white box located behind the radio. Remove the radio, then remove the plastic trim piece around the radio and climate control. From there, you will be able to remove 4 8mm screws from the white motor. Unplug the electrical connection and remove the motor. To put it back together, do the reverse of these steps using a new motor.
