Question about Compaq Presario 6010US (470027-054) PC Desktop
Won't boot up. Help!
My sister gave me her computer to use, but it won't boot up. The power supply seems fine because the fan starts running but it sounds like it powers up then slows down only to power up again. And it just has a blank black screen. Any suggestions? Is it the motherboard??
    President:
  • 2,961 Answers
Could be a number of things, but first check the disc shaped CR2032 cmos battery located on the motherboard, in case it is flat. Then when the pc boots, you should get the cmos menu to enable you to alter the time and date. If still no boot, when it is booting press F8 and see if you can get to safe mode, and when in the menu select last known good configuration and press enter or a reboot. If you see no bios screen and the flashing cursor appears in the top left of the screen the cmos chip on the board is damaged, and the motherboard needs replacing.
Posted on Aug 16, 2007
SOURCE:
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
My A/c won't start
Have an electrician check the capacitor in the unit as the motor will not run if it has failed.
Jun 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Compaq Presario SR1610NX won't turn off, and won't
The problem could be a hardware problem.
You can try removing the ram to see if it's faulty otherwise I am afraid you are unlucky because could be a motheroard problem so the only solution is to bring your laptop to repair service.
Feb 05, 2013 | Computers & Internet
COMPUTER WON'T START
See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
Feb 02, 2013 | Dell Inspiron Computers & Internet
Won't boot up and fan not running
Sounds like a dead battery or power supply or both...check for a light on the power supply to prove it's connected.
Jan 09, 2013 | Sony VAIO VGN-NR285E/T Laptop
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
I have an Asus Striker Extreme III motherboard running a q6600 with 4gb of patriot 1066 ram and an asus 8800 gtx video card. My computer has run fine for the last 3 years and had been working fine. Then a...
This sounds like the power supply - before buying a new motherboard can you get voltages from the pin connectors that power the board? You can use a simple multi-meter - set to 12V and register the current.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 01, 2017 | ASUS Striker Extreme Motherboard
Open Questions:
See all Compaq Presario 6010US (470027-054) PC Desktop Questions
Compaq Presario 6010US (470027-054) PC Desktop Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
