Question about GE Energy Star WCVH6260F Front Load Washer
Ge front load-
Washer compartment smells and last 10 mins on timer takes 30 to 45 mins.
We had the same scenario, only our clothes were still very wet when it finally finished the cycle. To cure all three we cleaned the filter behind the front panel. It was badly plugged and it, and the water it was holding up, smelled foul. So far so good since.
Posted on Oct 10, 2007
SOURCE:
I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type...
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Sep 05, 2010 | GE WBVH6240F Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Jan 16, 2009 | General Electric WCVH6800J Front Load...
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Repeating cycles
REPLACE POWER CONTROL BOARD SOUNDS LIKE TIMER PROBLEM
Dec 12, 2007 | GE WCVH6260F Front Load Washer
Smelly washer
I found out the hard way. The GE WCVH6260 fron loading washing machine has a terrible design flaw. There is a 'filter' that sits right in front of the discharge pump. This filter clogs with lint, coins, hair, dollar bills ... etc about every 3-4 months. When it 'clogs', the pump cannot '****' the dirty water through the gunk. As a result, you have nasty, stale water (forever) preventing dirty water from being flushed. What's worse is that since the dirty water cannot leave, you wind up washing/rinsing your 'clean' clothes with dirty water. It is easy to fix.
When looking at the front of your washing machine, there is a rectangular panel at the bottom. Remove the 3 screws (left, right and center) and pull down on the panel. It slides off easy. Right in front of you is a 3" cap. MAKE SURE TO HAVE A LARGE POT TO CATCH THE SLOP BEFORE YOU LOOSEN THE CAP. Remove the cap and pull out. (I took out 'gunk' the size of a tube of racket balls (coins, hair, dollar bills .. etc). You will also see/smell what I mean by 'dirty water'
GE is a bunch of idiots. We have only had our machine 12 months. This is obviously 'regular maintenance' kind of stuff (kind of like periodically cleaning the lint filter on the washing machine) and GE doesn't even make the 3" cap accessible from the outside. I checked the manual and these problems are not even FAQ's in the manual:
* machine 'pauses' between every cycle (push start to continue)
* clothes smell musty
* water doesn't drain
* cycles (consistently) take longer than timer says
* clothes still soaking wet even after spin cycle ... etc)
Dec 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washer won't stop!
Viv, hopefully it's just your filter thats clogged with lint and stuff. You will have to remove the front lower panel and the pump filter cover will be right in front. It just unscrews and pulls out. These models have a pressure switch that will not allow the machine to advance into high spin if it detects water in the tub. This is an easy job, just grab some towels and be ready for some water when the filter cover comes off. Clean out the stuff and see it fixes the problem..Catriver..post back.
Mar 05, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
198 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
