Question about Philips 32PT6441/37 32" TV
32pw6515 i have a philips 32pw6515,it has been working great since i got it then one day it decides to switch itself off. at first i could turn it back on and it would stay on for the rest of the day now it goes off as soon as i turn it on. i have no idea what the problem is,i took it to the tv repair man and he said if the tv had a10 on the tv at the back then it would not be even eorth me bringing it in as it would be well over £200 to be fixed. please advise me as i love this tv!!!!! thanks.
  • Anonymous Nov 08, 2007
    I'm having a similar problem with my philips 32pw6517/05
    Stays on for upto 30 seconds then turns it's self onto standby
It's the painter chip, ic 7064, and its very expensive, a repair that can only be done by a tv engineer at a cost of about £150.
Posted on Jan 21, 2008
    Genius:
  • 1,694 Answers
Replace bad capacitor(s) in horiz driver circuitry, usually at least
one 47mf/25v...............................T.
Posted on Nov 25, 2007
My philips css2123 appears to no longer receive power
I ran into this today. Searched the web and found nothing. I finally decided to do what you did take it apart and see if I could find anything obvious. Nothing visible found. I didn't tear it down 100% like you but while I had it apart I decided to remove one component at a time and test it after each piece was removed of course removing power at each step. I do not have the same model as you but once I disconnected the sub connection to the board I had full power. So I decided just to test this plugged it back in and I still got power. Went through reconnecting everything and testing between and once I had all back together the unit functioned with no issues. So just re-seating everything or clearing out an error by powering on with out that component connected seemed to work. Not sure if this will help with yours but decided to share what I found in hopes it will help.
May 10, 2012 | Philips CSS2123 SoundBar - 2.1-channel...
Sound on my philips 32pw6515/05 not working
the problem is dry joints om the main amplifier board or on the speaker wires.
check for those
okay
Oct 25, 2009 | Philips 32PW6506 32" TV
32pw6515 32'' philips crt no sound or intermitten sound
if the jack out side works okay, that indicates that the pre amp is fine. the sound on the pre amp is tapped before the main amplifier.
check the main amplifier ic in side if it is getting hot.
you need to charge that ic.
okay
Oct 24, 2009 | Philips 32PW6506 32" TV
Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Sep 09, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
No longer have original remote had one that worked now it now longer works what am I doing wrong Thanks for you help
Thanks for getting back to me. Decided just maybe it was in the control itself even though it was a new one. Went out and purchased a different kind and alas it works great.
Thanks again for getting back to me. Have a Great Day :o).
Apr 18, 2009 | Televison & Video
Intermittent turning itself off
check your setup menu and make sure that turn off timer is off
here is instruction below on your tv
hope it works
panasonic.com.au/content/library/files/F000518.pdf
Oct 27, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Tv philips 32pw6515 01
I can't turn on tv chanel. On the screen came LOCKED and after 5sec. switch off from self.
Jan 06, 2008 | Televison & Video
Tv turns on and off by itself,volume buttons on controller and panel don't work after while
An all too common problem with that unit is the Ssb or (small signal board, Philips p/n# PH3912725871 located just behind the tuner. It's actually a simple fix for a shop, what we call a plug & play repair but the part isn't so cheap. Last one I did thursday I bought from Vance Baldwin $267.82 plus shipping and core. You get the core back when you return the old part.
You might call a few shops like you know what you're doing and ask what they charge for changing the Ssb in your unit.
Have a great day!
Bill
Sep 02, 2007 | Philips 60P8341 60" Rear Projection...
Philips 26pf5320
Hello, one of possible solutions is to replace T7735 by the same type of transistor and L5753 (220uH use 470uH). This is a job for a technician. Best regards, Arpi
Apr 09, 2007 | Philips 26PF5320 26 in. LCD Television
Flashing red light and shutting itself off
try to elevate the projection tv about an inch...
it well most likely work...
it's a ventilation problem.
Feb 09, 2007 | Philips 55PL9223 55" Rear Projection...
Philips 32PT6441/37 32" TV Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
