Question about AcerScan 620PT Flatbed Scanner
ACER 620 P SCANNER
I have windows 98 and just instaled the software driver discs for the above scanner. They are Mirascan V3 20 and ULead Photo Shop. When I try to scan, I receive the following error message READ IMAGE DATA FAILED PLEASE RESTART THE SCANNER CODE 0024 When I restart the scanner, message states SCANNER IS WARMING UP, open Ulead Photo Shop, select SCANNERS, then ACQUIRE, THEN I select the SCAN command and the aforementioned error appears. I have also tried to uninstall/reinstall Mira Scan several times. Please help me. Thank you
  • joseph_1509 Jun 20, 2008
    same problem
  • Anonymous Mar 28, 2014
    i don't know what to do
I Want Mercury Scanner 620P windows xp Driver
Posted on Mar 26, 2009
SOURCE:
Ineed mirascan v3.04 driver for win xp
Hi!
Here's version 3.40...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | AcerScan 310S Flatbed Scanner
Actullay, sir, i broughted this scanner systems about 10years old that time in pakistan win xp is not produce properly i have orignal cd of scanner but this driver the said cd valid for win98 and millinium...
How to make any Acer/BenQ/Vuego/Brisa parallel port scanner work in Windows XP (note: this procedure does not work in Windows 7 or Vista, only in XP):
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web: ftp://12.145.38.159/scanner/drivers/parallel/mirascanv3424p.zip
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on "EPPSCANNER" and where it says "Model" it should say "color flatbedscanner". Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: ftp://12.145.38.159/scanner/manuals/scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but the procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
Note: This solution does not work on all computers but many report success with it. The hang-up is caused from certain chipsets in the computer motherboard.
Sep 04, 2010 | Acer ScanPrisa 640P Flatbed Scanner
I have a scanner ACER PRISA 620P by LPT1 connection and my OS is windows 7. When I run the software (photosop), i push the option "File" and then Import and then MiraScan 3.42.... The answer of Mirascan...
uninstall the photoshop restart you pc then install it againg. Restat the pc and try to use it.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | AcerScan 620P Flatbed Scanner
I have an old Mirascan v3.04 620UT flatbed scanner (windows 98)
There is no Vista driver for this Acer scanner.
Acer didn't create a vista driver for it. (or Benq)
More info:
http://forums.driverguide.com/showthread.php?t=19603
Jul 22, 2009 | AcerScan 310S Flatbed Scanner
Bundle software
Need driver for windows vista.
Sep 11, 2008 | Acer S2W-4300U Flatbed Scanner
Driver download
You need to download and install drivers again. The only website distributing drivers for Mirascan is this one , as Acer dose not provide drivers for this device anymore. You will need to subscribe to website to download drivers
Unplug Scanner before installing drivers, plug it back only when finished installing or when required
Jun 08, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Acer ScanPrisa 640P driver for Windows XP
I have acer scanprisa 640p.Before i have 98 windows.Now i have in my computer XP windows.Now this scanner is not working in Xp Windows.Pls send me driver of XP.So that i can use in XP windows.I am very thankful to u.My E-mail Is [email protected]
Dec 10, 2007 | Office Equipment & Supplies
Installation CD
I had to download two different drivers to get my AcerScan320U to work in Win2k (WinXP is easy, as the drivers are included with WinXP). MiraScanv3.42 does not work, but it has good drivers for getting the scanner properly recognized. After that, MiraScanv4.03u10_BQA from Benq will work, and installing it is point and click.
Specify the location of the older (V 3.42) drivers.
Select the file called EPP2K.
Check "Install one of the other drivers".
Select the Benq as shown in the next two images, and then select Next>.
Sep 26, 2007 | AcerScan 320U Flatbed Scanner
AcerScan 620PT Flatbed Scanner Logo
437 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Steve Allison
Steve Allison
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
