Question about Insignia IS-PDVD10 Portable DVD Player
Lid Came Off and I cant get it Back on right
I trid to put it back in and I have all the parts, but it still does not work. Can someone please help.
    Novelist:
  • 170 Answers
This is not a small job. The lis is one of the first chassis pieces that is put in place, then the drive, boards, buttons and so forth.
Make sure that both tabs on the back of the optical door are still there. I've seen a few where one of the tabs breaks off and the lid just flops around. The small metal plate needs to have it's screws that will mount it on one side, and the spring needs to be there as well.
If you have a screwdriver and are very brave, you can repair this yourself. Otherwise it's a repair for the Insignia repair team.
Posted on Apr 17, 2008
SOURCE:
How to get number to reset laptop password 5250 acer
havr you trid to refnat it ?as long as you have a windows set your boot ti cd-dvd then dont put in a parrword
Sep 15, 2014 | Acer Aspire 5250-0639 1.65GHz AMD...
Panasonic has discontinued the accessory PV-A20
HAVE YOU TRID EBAY OR GUMTREE FOR A SECOND HAND ONE THAT YOU CAN TAKE THE PART OFF
Apr 08, 2014 | Quasar VM-L153 VHS-C Camcorder
Cant log in
Hi Javier,
Try login in like you 'forgot your password'.On the Facebook Sign Up page,and under 'password' is the
'forgot your password?' option,click on that and follow the instructions.
Or follow this link on your phone www.facebook.com/recover.php
Hope this helps.Thanks!
Dec 18, 2011 | Facebook Computers & Internet
I have a Toro 12V Battery Trimmer, a small pin has fallen out of it, now it will not run, what can I do with it? Please do not sell my email address.
No selling, just helping here! I found this diagram for you. Maybe you can get someone to help you put the pin back in where it belongs. It is the only pin I could see in a parts diagram for this type machine. It is part # 2 and is called the Spirol pin. Once it is back in place it should make the motor turn the string head again. Again, I hope you find someone to help you put it back in place. It goes in through the shaft of the electric motor so disassembly will be required to access it.
http://www.partstree.com/parts/?lc=toro_commercial&mn=30950%2C+12+Volt+Electric+Trimmer%2C+1980+%28SN+0000001-0999999%29&dn=3311_546-1_546002-0002
Sep 25, 2010 | Toro Garden
I have a Maytag LA212 AND a Maytag A8120 washers that will both fill but then do nothing else. The A8120 I got first and it just started this behavior last night then then today someone put out the LA212...
I used to have 2 laundromats full of toploader Maytags... these will fill and do exactly what is happening to you if the LID SWITCH is not activating. Open and close the lid and listen for a clicking sound. Look a the rear edge of the lid... there is an indentation that is supposed to activate a small white switch in the that's attached to the top of the machine. Many times the lid will simply get bent.. someone sitting on the lid, standing on the lid... will be enough to throw it out of whack. Close the lid and push on the center of the closed lid... will the machine work? Or carefully push a flatblade screwdriver tip between the lid and the switch to see if you can get it to activate. Solution: Open the lid and apply firm pressure on the lid towards the back of the machine, while with the other hand push DOWN on the back edge of the lid...right where the indentation for the switch is... if you give it a slight tweak...you'll probably be back in business. One other thing, if the lid switch isn't clicking...replace it.
Sep 12, 2010 | Maytag HAV2557 Top Load Washer
Bernina730
HI
All that is wrong is that the plunger that holds the lid down is likely siezed with old oil. If you are careful you can slowly insert 2 flat sided screw drivers under the front part of the lid on either side of the right and left side of the lid and slowly move them toward the middle , thus the plunger will likely give way and the lid will pop open.
If this does not work contact me at [email protected]
Wayne Buss
Apr 18, 2010 | Bernina Bernette 75
Lost alot of channels on the starview box trid rebooting box no luck can anybody help me pls or have the codes change
Hi
Try putting it back to factory setting and re-installing channels. Dont forget to switch EMU back on. It is a pain sorting all the channels again but worth it to recover lost channels.
Mar 26, 2010 | StarTech.com StarView SV211K 2-port KVM...
Trunk lock broken by uninsured motorist
to put on a trunk lid is very simple usually 4 bolts on the bottom near back window. As far as locating a trunk lid look under auto salvage in the yellow pages tell them what you need they can locate the part for you over their network. Anyone with a wrench will be able to install the lid as long as there is no other body damage
Sep 30, 2009 | 2001 Volvo S40
Ac wasnt cold trid putting freon and think i may have busted lines saw dye coming out of seal on line what to do
find out which seal its whitch line or hose going to wher and explanin it to the parts man ,,and take the old seal with u
Jun 29, 2009 | Chevrolet Malibu Cars & Trucks
Insignia IS-PDVD10 Portable DVD Player Logo
100 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
