Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water line The water lines in the GE side by side are broken. How does one remove them from the water-cooler reservior? The ice Maker line is ok..
  • 4 more comments
  • lizardlips Aug 17, 2007
    I cut the 5/16 plastic line off as short as possible.
    Then using a 3/8 dia countersink with a 3/16 pilot I drilled out the tube down to the black rubber ferrell.
    Then I tapped out the white plastic 1/2" tubes and installed threaded brass fittings. A small hose clamp was added ..
    Time: 30 minutes
    lizardlips
  • grhoades Nov 18, 2007
    The GE TPX24BRBAWW side-by-side refrigerator in our home as well as the family across the street have the same, terrible, destructive problem; Try to dispense cold water from the freezer door and water is dispensed onto the floor at the back right of the unit. The 5/16" line has failed near to the solenoid valve in each case. The water spreads across the floor and is absorbed into the base molding and wall causing substantial water damage. The failure appears to be due to either the materials or the design that routes the line immediately adjacent to the hot compressor unit.
    GE shipped us the wrong part to fix the problem. All they need to do is offer a section of 5/16" line and union connector but THEY DON'T. And I can't seem to find the parts due to the wierd size. 1/4" and 3/8" is at every Home Depot but 5/16"??? So it would seem GE stranded a huge number of owners with no part to remedy their product's flaw. Maybe I can find a 5/16" to 3/8" adapter and then just use some readily available 3/8" line to fix the problem for a while.
  • Anonymous Jan 01, 2008
    I have had the same issue.
  • bertrand Feb 19, 2008
    have ge monogram side by side I can hear the water going to ice maker but it doesn't get there. water goes to the ice water dispenser fine, just doesn't get to the icemaker. If I put water into the ice maker it makes ice cubes normally.
  • jntdeim Aug 24, 2008
    My GE side-by-side model ESL25X had the same problem where the water was gushing from the bottom back right-side of the refrigerator after attempting to get water from the dispenser. I found that the water line was completely broken and it appears as though it's because the tubing just got old and brittle and it broke right by the water valve where it makes a loop to go up to the water dispenser. There is a 3" section that connects to the water valve and I can see a couple of feet of extra tubing inside the unit but I can't figure out how to remove the short piece so I can simply cut off some of the old tubing and piece it back into the water valve. It seems like a pretty straight forward repair but I can't seem to get the pieces to the water valve apart.
  • gturda Dec 28, 2008
    I have the same problem. The polystyrene water lines are broken off inside the refrigerator (right, rear). It would appear that this would be an easy fix, but do not know how to remove the tubes from the assembly. A service repair manual would be very handy. Are these available anywhere?
I do not have a manual, my frig is a TFX24s and it just does not cool off what can I do?
Posted on Dec 28, 2008
I have a GE TFX24SMA. The 5/16 inch replacement water line part number is WR17X10206 or PS291410 available from PartSelect.com for $74.25.
Posted on Mar 27, 2008
  • 283 Answers
There is such an adapter. I use them all the time. They come in water valve replacement kits that are available for Maytag and Amana units. They're not always used so there are lots of spares lying around. Check with your local appliance parts dealer. When replacing the line keep it away from the heat!
Posted on Dec 30, 2007
SOURCE:
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I have a GE model TPX 24BPBA WW and have a water leak on my floor. I disconnected the icemaker water feed and leak stopped. What's wrong
do you live in an area where there are rodents such as mice ? if yes there is a possibility that they have eaten the plastic water line that feeds from the ice maker water valve to the ice maker itself . when they get thirsty you would be surprised what they will actually chew through to get water. regardless the cause, you probably have a broken water line between the ice maker water valve and ice maker unit .
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker on side by side refirgerator will not quit making
Hello there
Please try these few tips ok?
  1. It may be turned off. Check the Ice maker shutoff arm located at the top of the ice bin. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, simply lower the wire.
  2. Is there water in the ice cube tray? If not check for water to the water valve. If you have water then it could be either a failed fill valve or ice maker control module is not activating the water valve.
  3. Check for pinched water supply line (behind the fridge)
  4. Do you have an inline water filter? If so, when was it changed last? To test if it is plugged, check for water both before and after the filter system.
  5. Sometimes the water inlet tube that directs water into the ice cube tray freezes over; this can often be thawed out by simply using a hair blow dryer and warming the area (be careful not to overheat the plastics as they can warp or crack). Then adjust the freezer to a slightly warmer setting and make sure water is not constantly dripping from the inlet tube, as it will only freeze over again.
  6. If it continues to drip we may need to replace the water control valve.
  7. The ice maker head assembly may have broken parts. Look to see if the gears are broken.
  8. Check to see if the small plastic arms that rest against the ice rake are broken.
  9. If the ice maker head assembly is modular and you've found broken parts,
Nov 08, 2009 | GE Refrigerators
Ge ice maker wont make ice , no water entering tray clynoid water valve ok.
Take the front cover off of the ice maker.  Under the cover there are some test points,  V stands for valve and should have 120,  L stands for line and should have 120,  N is nuetral and should have continuity to ground. If all of these check good replace the ice maker, If not troubleshoot the wiring.  The fastest way to find out if it is the ice maker it to jumpre the two middle terminals on the ice maker plug.  If it spits out water replace the ice maker.
Oct 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water does not dispense
there should be a water line that runs from the reservior that is in the fridge compartment under the appliance to a connector at the bottom of the freezer door, if water is getting to there then the water line within the freezer door is frozen . If water is not getting there then the reservior may be frozen or the watervalve may be faulty
Nov 24, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
911 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Jeff sanchez
Level 1 Expert
