I have a maytag dehumidifer in my basement, hooked up to a hose leading to a drain. The problem is, the dehumid. doesn't recognize the hose connection. It continues to dump water into the reservoir, and I have to empty it constantly.
I cannot find the manual and found this site online. Hope you guys can help!
-   I had that problem when I tried a garden hose. I changed it with a grey plombery pipe and it.s work now (not sure if it's PVC pipe) -   Guest
Aug 20, 2008
-   i added a hose to the back of the unit but it still puts the water in the tank -- i hate emptying it all the time. please help.
-   erin53719
Jul 20, 2008
-   I tried attaching a hose but water continues to collect in the bucket and the unit shuts off when the bucket is full. -   gcsz
Jul 11, 2008
-   Dehumidifer only extracted water for 20 minutes then never worked after that. Compressor does not seem to be coming on.. Tried to find the defrost switch could not find ....without maybe taking all apart(don't want to do that)any suggestions as what to look for would be appreciated.
Thank You
D.W-   Guest
Jul 03, 2008
-   Yes, I have the exact same problem. It won't continuous drain through the hose even though the hose appears to not be clogged. It is a pain to have to empty it every day! Help!
Thanks for pointing out the Fedders link! I saw a Fedders tag on the back of the unit but also the Maytag brand. Maytag's site certainly doesn't acknowledge this unit's existence.
In addition to checking the connection point, as johnsoncd mentioned, you should also make sure your drain hose is not plugged. I just discovered today that the drain hose hooked to my Maytag M7DH45B2A was plugged. A couple of months ago, my bucket kept filling up, as was posted by Hurlingboy. There is an overflow hole that, I presume when the dehumidifier is level, causes the water to go into the bucket if the drain is plugged. I believe I may have repositioned the unit, because instead of filling the bucket, it started to leak on the shelf that it sits on. It occurred to me that the drain hose might have been plugged, which ended up being the case.
I tried several different sizes of soft and hard tubing and finally found one that works. The attached tubing has to be absolutely snug around the spout and when it arcs slightly downward, the water goes into it rather than the bucket. I attached garden hose to this 3 inch length of tubing. It took me at least ten tries before I found the right size and angle. At last!
Did you check to see if the adapter that you connected the hose to is pushed all the way into the unit so it covers up the smaller tube that allows the water to drip into the water collection bucket? The other end of the tube does not screw into anything it just slides over the smaller tube.
try using a cue tip swap to clean-out the connection point inside the unit. If you can remove the front cover of the unit you can also clean out the little drain tube on the other end. Reconnect your hose and it should work. If not your drain pan might need to be replaced and it's not worth the effort - get a new unit.
I have the same problem and discovered there is also a small hole in the plastic collection tray at the right end of the tray. You can see it when you remove the filter screen and use a flashlight to look inside and to the right of the filter slot, or you see it when you remove the collection tank and look up at the plastic tray from the bottom (it's right above where the float is in the collection tank). Maybe it is an overflow opening that allows water to escape into the tank if the hose becomes plugged. I suspect that if the unit is sitting on a floor that slopes down to toward the right side of the unit, this small hole will constantly drip water into the collection tank. I see three solutions: (1) change the orientation of the dehumidifier, so it slopes to the left (2) place thin shims under the right side wheels of the unit, so it slopes to the left (3) fill the small hole with silicon rubber or a small cork. (By the way, instead of using the hose adapter and a hose, you can also use 1/2" inside diameter clear pvc hose that you buy by the foot at a hardware; it's a snug fit but it works great.
Was this helpful?
Yes
No
Popular Solutions for Maytag M7DH45B2A Dehumidifier
it doesn't collect any water in the bucket . i haven't used it in weeks and when i runed it for a...
(More)
it doesn't collect any water in the bucket . i haven't used it in weeks and when i runed it for a night i noticed it does'nt collect any water . tryed it several times but without luck. thanks menn.
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell...
(More)
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell me a new bucket?
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has...
(More)
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has always worked great until this week. It seems to still be working, but there is a large wet spot in front of the unit which sits on carpet, so I know it is leaking somewhere, but the water bucket is still filling, and I can't see where the leak is coming from. Should we bother having it repaired or just purchase a new one. I am not sure what the life span on this item is. Has anyone had this issue?
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing...
(More)
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing this noise? What do I do to fix it? It's 4 years old.
