Question about GE Corded Phone
RCA 25415RE3-A 4 line phone
We have caller i.d. with three main phones in our offices. My phone (#1 base) has stopped showing the caller i.d. information on the display area. What can I do. The other phones are OK.
SOURCE:
  • 201 Answers
SOURCE: Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Posted on Jul 07, 2007
SOURCE: Registering a new phone
I tried your solution - putting the phone on the answering machine charger and it worked! Thank you!
Posted on Dec 28, 2007
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
SOURCE: Answering machine no longer works
Wow..SAME thing...this phone system has gotten to be about 10 years old and the gurus or factory service won't help you out too much because of the bell and whistles it has...and time is money eventually...keypad membranes go bad..bugs get in them...the crawlly ones...if they share the place..my "initialization" left me throwing away the headache and going to Walmart...FIX YA!!!!!
Posted on Aug 31, 2008
  • 37 Answers
SOURCE: phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Posted on Apr 29, 2009
We have Panasonic KX-T7731 telephones in our office. we have three incoming lines and approx. 7 extensions. the phone co has assured me they've turned on caller id capabilities for all three lines but...
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Mar 15, 2011 | Panasonic KX-T7731 Corded Phone
Hello, we were having phone problem with our main phone and swapped it for a extra phone we had in storage. Same model. In doing that, we lost our caller ID on the main line to our business. When we...
According to the manual, the RCA 25413 does not support Caller ID. I have provided a link where you can download the manual. The manual is for model numbers 25413 and 25414. On page 8 it details how to turn caller ID on/off for each line under Ringer Tone heading item 6 Note, but the note says it does not apply for model 25413. Hope this helps.
http://www.rca4business.com/products/pc/pdf/instruction-book/25413RE3.pdf
Feb 24, 2011 | RCA 25413RE3 4-Line Corded Phone
Need to know if caller id can be manipulated in an avaya system?
That is something you have to set up with the line provider. Partner can not send caller ID information
Feb 18, 2009 | Avaya IP Office 4690...
Caller ID suddenly stopped working on our KX-TG5771 cordless sets
I have had similar problem the way I solved it .
Unplug all units from ac
Take out all batterys
unplug phone line.
Put back in reverse order .
They allways seem to work after.
I have noticed that if the phones are charged on the wrong stations they seemed to get confused for some reason.
Hope this helps
Doug
Dec 13, 2008 | Panasonic KX-TG2357 Cordless Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Mar 26, 2008 | GE 28112 Trio Cordless Phone
No Caller display
I have had Several problems with the Freestyle 2200 phones.
The best solution I have found is to remove the rechargeable batereis for 30 seconds and then replace them. This seems to work every time.
Jan 21, 2008 | British Telecom Freestyle 2200 Trio...
Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Jan 08, 2008 | RCA 25414RE3 Corded Phone
GE Corded Phone Logo
141 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
