Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore / GE side by side defrost drain keeps freezing up
The water captured in the defrost drain pan on my Kenmore / GE side by side freezer freezes up causing water to pool in the bottom of the freezer and then this water freezes too. What can cause the water in the defrost drain pan to freeze up? The drain is clear. Couls to long a heated defrost cycle cause this problem?
  • 4 more comments
  • chschapira Aug 23, 2007
    The line is clear. Water flows through after I de-ice.
    the drain line is not blocked. Once I de-ice the catch tray the water flows well.. the challenge is that the water is freezing within the drain tube and in teh catch tray.
  • 25_06guy Nov 24, 2007
    Built in GE ZISW36DYA side by side with overhead compressor ....... above the ice maker (ice maker functions normally) at the very top of freezer is pan (defrost collector? ..... finger contact only through some holes) ..... water accumulates and freezes in the pan ..... I can feel a coil and fin assembly just above the pan ..... water then overflows the pan sides and down the side of the freezer walls collecting in the bottom. Suspect the defrost pan drain line is plugged and/or frozen .... unable to see or locate the drain line ....... is there a collection pan at the bottom of the unit? I've read an opinion of drain pump that needs revitalizing .......... HELP.
  • Anonymous Mar 22, 2014
    defrost water does not get to drain pan
  • Anonymous Mar 23, 2014
    GE freezer
  • Anonymous Mar 31, 2014
    water not draining
  • 183 Answers
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
Remove back of unit and check defrost heater has not become detached, otherwse the is only two possibilities, one a defrost fault and although you say the defrost tube is clear the only reason it does not flow is due to a restriction, what can happen is that the water backs up the drain pipe and then freezes before the water in the external tray can evaporate. Regards Advisor
Posted on Aug 24, 2007
GE Side-by-side refrigerator defrost drain trough keeps freezing up. Drain tube is clear and never gets frozen but ice builds ups and overflows into the bottom of the freezer. What is causing this?
Sounds as if the defrosting timer or the heating element has gone out. Since the fridge works without problem off and on I would lean toward the heating element.
Mar 26, 2016 | GE Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Condensation drain hose freezes - water drains into frig.
The problem is probably the drain itself. It is probably partially clogged. Another thing could be ice build up. I will usually get a peice of metal coat hanger a few inches long and I will hook it over the defrost heater and let in hang into the hole about an inch or so. That way when the unit defrosts that hanger will heat up and keep it from freezing.
Sep 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
No cooling no freezing puddle on floor
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Apr 23, 2009 | Kenmore 53642 / 53644 Side by Side...
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Jan 03, 2009 | LG LFC25760 French Door Refrigerator
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Drain hole plugs with ice
this is a perpetual problem due to no drain heater being fitted. what may help is to run some pieces of copper wire from the defrost heater and have them into the drain hole. enough heat may be conducted to cure it
Sep 17, 2008 | Haier HTX18GAAWW Air-Cooling And Automatic...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,521 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
