Question about TruTech PLV1615T 15 in. LCD Television
Trutech 35" LCD connecting to cable box
Ok, I know the quality of this TV is not good but wondering what causes this. Have cable box hooked up to TV with video cable (yellow/red/white) into input (AV1). What is weird is local channels come in fine (abc,cbs,nbc,pbs etc.) However, when you change channel on cable box and go to a cable channel like TNT,WBS it displays it at the bottom of the screen like all the channels but just stays black. It does this for all cable channels so it shows what channel it is at the bottom of the screen but isn't displaying it. The trutech TV doesn't have a channel set/format option like other TV's so wondering what is going on?
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores. So many companies make their products. This website isn't the official site for all Trutech products,just some of them, like this 15" LCD TV.
Posted on Aug 20, 2007
SOURCE:
Precision TV - PTV2548 no sound when your watching cable but there is sound forvideo input
may be the source itself(i.e. cable box) also check cables between cable box & TV. If you are connecting the DVD to the same input the cable box is installed, You know that input on the TV is OK. If you get no audio when the DVD is connected to the same input as cable box, then issue is the MAIN PCB.
May 21, 2014 | Televison & Video
I have a trutech pLV16320 LCD tv, do i need a converter box?
Hello
There is no details or user manuals in NET about your Trutech TV. If you have its owners manual with you now, go to its specification page, and see whether this TV have internal digital tuner or not. It will be speicied there. If there is internal digital tuner, you need not buy an external converter box. In not you have to. OK.
Oct 17, 2011 | TruTech PVS31170S1W 17 in. LCD Television
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
The coaxial cable connection into the TV loose so the picture is snowy. How can I fix it?
You do need to buy good coaxial cables at a reputable electronics store. You may sometimes use the slide in one with some luck. I prefer a high quality cable purchase at the cable or satellite tv office. The other thing is you may have too many connections going into the tv. You may a dvd or vcr player that is still on. Or the video game box is on etc. Or worse yet...the RF connector on the tv itself is loose and will require a new soldered one in its place...this will require a tv tech! Or the quik fix is to bypass the RF connector and use the RCA cables and Jacks. Hate to leave you with so many options...but most is covered now...good luck!
Dec 19, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Akai lct42z6tm
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Feb 21, 2008 | TruTech PLV16320 Television
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
TruTech PLV1615T 15 in. LCD Television Logo
350 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
