Question about Sony Ericsson W850i Cellular Phone
SE w850 i displaying strange codes instead of after falling down !
...so i can receive and make calls but cannot access the menu nor read texts as all appear in codes.. i guess i should reset to factory setting.. but how do i do that if only strange codes are displaying when i try to access the menu as if the languange has been set to codes ??? the background picture is displaying normally meaning my lcd is fine !! any idea? anyone one got a similar problem? thanx
    Brigadier General:
  • 7,752 Answers
Tak the phone and have the firmware reflash
Posted on Aug 19, 2008
How do I stop the reading out loud of my texts on my LGIP-340NV
Hi Lori,
Your phone is set to read text. To stop this feature, you do the following;
From the settings menu, scroll down to accessibility, you will see a hand icon. tap on it and un-check the Text-to-speech output.
You might have installed an application called Speak Caller Name on your phone that is reading your text too. Check that and switch it off or configure it to stop reading out loud.
Hope this helps.
Sep 26, 2014 | Cell Phones
My nokia c6 01 is locked by phone lock code. How to unlock it?
you may visit some master reset code sites........
Jun 11, 2011 | Cell Phones
We a incoming fax comming, we don't get fax but fax call report with "comm error 392"
Assuming you have an HP laserjet, you can either try again in a little bit or disable v.34 on your machine and use v.17 instead
Perform the following to turn V.34 off and access the lower speed of the local machine.
1. Press the ENTER/MENU button one time.
2. Press the or > button until the front display reads "Fax Setup".
3. Press the ENTER/MENU button.
4. Press the or > button until the front display reads "All Faxes".
5. Press the ENTER/MENU button.
6. Press the or > button until the front display reads "V.34".
7. Press the ENTER/MENU button.
8. Press the button until the front display reads "Off" and then press the ENTER/MENU button to save the setting.
Feb 28, 2011 | Office Equipment & Supplies
Missing Calls and Texts. Alarm Caput.
Cause:-
Call logging is not enabled for the Message list.
Ensure call logging is enabled from the Phone application Options menu.
1) From the Home screen, open the Phone application.
2) Display the menu and select Options.
3) Select Call Logging.
4) In the Show these call log types in message list field, select the type of call log to be displayed in the messages list.
5) Display the menu and select Save.
I hope I was able to help you.
Nov 23, 2009 | RIM BlackBerry Pearl 8100
On my incoming mail with Yahoo, the type face is very small and hard to read, any ideas on how to increase this size
"Ctrl" + "+"
ie. hit "+" key while Ctrl key is pressed.
Please Rate if you find above info useful.
Aug 24, 2009 | Computers & Internet
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Pan Tech Duo... New Texts and Silent
After you read a message, always hit the return/back key to get you back to the main list of messages. This phone automatically returns you to wherever you left off last, so if you don't hit the return key, your last message read will be what is displayed when you hit your message key.
No, your phone is not defective, you need to change your settings.
In your menu, go to SETTINGS, then PROFILES. Scroll to the profile you are using then select EDIT. Under each profile you have the option to select how your phone handles any alert you receive (i.e. for calls, messages, texts, etc.) You have several options some of which are silent, silent and vibrate, vibrate only.
Personally I want my phone to vibrate when it's on silent so that I know I'm receiving a call or text. You can choose another option though.
Jul 31, 2008 | Pantech Duo Smartphone
Text Messages ort Calls will not open
I would definitely reset the phone, unless you can find a way to clear the text messages out before it crashes to the Main Menu. My guess is that you have a corrupted text message in your inbox, and it is crashing the software.
Resetting the phone will wipe out all of the data on it, so make sure you back it up first. If you have the Motorola Phone Tools, you may also want to try accessing the text messages or updating the phone software through it first.
Dec 18, 2007 | Motorola Mobility RAZR V3
Need complete recent call log and more days for text message storage
The call listing only shows one caller by design, to help with clutter on the list. It's a little funky, but if you think about scrolling through pages of the same caller just to find that number to the pizza place again, it makes sense.
If you open Messaging, you can access the settings in the menu there to increase (or set to never delete) text message life.
Please let me know if you get stuck!
Sep 13, 2007 | Motorola Mobility RAZR V3
Sony Ericsson W850i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
