Question about Epson Stylus Photo R1800 InkJet Printer
R1800 Borderless Printing Problem
Has anyone had a problem with borderless printing on the R1800. My printer leaves a very narrow white band on the trailing edge of the print with no ink. I thought it was the printer after call their Tech Support, but the new printer they sent has the same problem. Has anyone else experienced this? Any fixes? Thanks, Tom
  • Skykingbird Aug 16, 2007
    Thanks, Inky....your last paragraph was a big help....I pulled out those little tabs on the bottom tray and that seemed to help. I also went to Paper Handling and checked "Scale to Paper Size" and unchecked "scale down only" which eliminated the white banding completely.
    I've got my fingers crossed....thanks for your help!
    Tom
  • jimt141 Dec 16, 2007
    I also have a white band on the trailing edge of borderless 4X6 prints. I also went to Paper Handling and checked "Scale to Paper Size" and unchecked "scale down only" but it has no effect. Any help is appreciated.
  • Epson Master
  • 705 Answers
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Posted on Aug 16, 2007
SOURCE:
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
How to do borderless printing with an oki c5300
You cannot do borderless printing with a toner/fuser based unit.
The printer needs a paper grip area and cannot print to the edge due to the fuser.
Sep 30, 2009 | OKI C5300n Led Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
When printing to an Epson R1800 have a problem
Make sure the paper size is not set to US letter sheetfeeder borderless use just US letter. the borderless function slightly enlarges document content to ensure that it bleeds overthe edge. If your has a bleed, use in page setup - US letter sheetfeeder borderless - In the print dialog box click printer button which brings up a warning about using a different settings dialog box, - continue on to the r1800 print dialog box. about midway down is a pull down menu - choose expansion and adjust it to the lowest setting. if your printout does not bleed to the edge bump the expansion adjustment up 1 measure.
Apr 11, 2009 | Epson Stylus Photo R1800 InkJet Printer
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson R1800 prints do not lay out on paper correctly; off center
Hi-
But goal is to have a borderless printout right? when you go to page setup and choose paper sizes when you go to letter size, does it have a slider for letter- borderless? and when you go to file print and and check the print setting/ print layout is fit to page selected?
keep me posted. Thanks!
Jul 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
672 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
