Question about Kenmore 43042 Front Load Washer
My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
My machine will not start because th emagnet that locks it fell out. I have the magnet, I can see it on the parts diagram but it is not exactly clear where or how it attaches to the dispenser door. Any suggestions?
  • bjr1 Nov 09, 2007
    i have the same problem. a small rectangular magnet fell out of the dispenser drawer and now the machine won't start. and i can't figure out where it goes. would love to find a nice diagram. found the same question on allexperts but no clear answer there either.
  • Anonymous Feb 17, 2008
    Have same problem --- where does this magnet go?! HELP!!!
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Posted on Mar 29, 2008
SOURCE:
How to put the magnet on drawer gltf294es1
Might be best to go to the assembly diagrams for your washer on this site and work out the part type and where it needs to be.
Frigidaire Washer GLTF2940FS1 Repair Parts
Sep 02, 2014 | Frigidaire Washing Machines
OP display light comes on when hitting start. Then hit off & in a minute it comes on?
Most times this issue is caused by loss of signaling thru the Left Hand Lid Lock.
1st check for a Lid Magnet out of position. This is an easy check if you have a couple key holder magnets or a similar magnet that you can place over the Left side grey lid bumper. Let's see if you can close the Magnetic Reed Relay switch with an external magnet and send +12VDC up to the Control Board and clear the "OP" error code.
If that doesn't clear the "OP" error code we will need to remove the Left Hand Lid Lock and check to see if corrosion is part of the issue. Because of its proximity to that nasty bleach dispenser it will cause issues. Here is the lid lock to order.
Here is a picture of a bad lid lock.
Nov 22, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Door fell off. Can't put it back on.
Hello sir; on the door there have two pieces magnet when you close the door it will stick on the metal on the machine check it and find out these two magnet is there/
Jun 04, 2010 | Toshiba Office Equipment & Supplies
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
"OP" ERROR CODE
Take a look at this post, it’s for troubleshooting an OD alarm but you can follow the same troubleshooting path to see if you have a lid magnet out of position or a broken lead on the magnetic reed relay located in the left lid lock. The lid magnet operates the magnetic reed relay to signal the lid is closed/the lid is open. Try an external magnet on the left bumper and see if that clears the OP error code with the lid open. If it doesn’t I would try reseating the left lid lock plug (possible corrosion issues). If that doesn’t clear the OP alarm it would be time to pull the life lid lock out of the machine and inspect for a broken lead on the magnetic reed relay or other corrosion issues with the left lid lock. The left lid lock is in a location near the bleach dispenser. Links to the SM are in that post and a link for parts look up. Post back if you have questions
Jun 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I turn on my maching and the door locks, but nothing else happen
I had the same problem within my 1 year warranty. I called the company and they sent out a repairman. Apparently, there is a magnet in the drawer that lets the machine know the drawer is closed and it is safe to start the cycle. If the magnet isn't there the machine doesn't think the drawer is closed and won't start. The repairman simply had to replace the magnet and the washer started after that.
Apr 13, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag Neptune keeps giving us the OP signal
Hello Kristi,
If its FAV6800A/FAV9800A try placing couple 1” dia magnets or similar magnet on the left bumper of the machine and see if that will clear the the “OP” lid open alarm, see pic attached. If that clears the alarm the lid magnet may have moved out of position in the inner lid. See page 33 of the FAV6800A/9800A Service Manual for its location. If that doesn’t clear the “OP” alarm remove 120VAC to the machine and try reseating the left lid lock plug into the left lid lock a few times to possible clear corrosion causing loss of signaling from the left lid lock to the control board Lid Is Closed input. See page 33 and 34 of the SM for pics if the left lid lock and lid magnet. I recommend surge protection on the120VAC outlet powering the machine to help protect the washer control board. Good luck Rich.
Place some external magnets on left bumper and see if that will clear the "OP" alarm.
Try reseating the left lid lock plug into the left lid lock. Be careful, it may be difficult to remove for the 1st time.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 43042 Front Load Washer Logo
237 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
