Question about Hifonics Brutus BX 1505D Car Audio Amplifier
How to reset my system?
Okay i have the red power light with no sound going through the amp i was told to reset my sysetem? how would i go about doing that? if it helps i have a 1996 monte carlo
  • 113 Answers
Disconect all power cables then short between terminals G&P G&R .a little spark but ok.try after 10min.
Posted on Aug 22, 2007
SOURCE:
SOUND IN ONE EAR PEIXE
Of course, you know that your phone has to support A2DP in order to get stereo sound. If that aspect is okay, perform a system reset: While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset. If it's still giving you problems, contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Good luck from Headsets Direct!
Jul 24, 2011 | Plantronics Backbeat 903 Bluetooth...
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
No sound or lights
make sure the yellow wire has power all the time and the red wire has power when the key is on. Most likely you do not have power to the red.
May 19, 2010 | Boss 506CA CD Player
Computer wont boot. LCD are on. No sounds at all.
Yup. Please try to remove the battery and use ac power. Please try to turn it on and see if it is still the same. It is safe to put the battery back in even if the laptop is on. Hope this works. Thanks.
Sep 30, 2008 | HP Pavilion dv2000t Notebook
Red light on my amp?
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
May 22, 2008 | Pioneer GM-5200T Car Audio Amplifier
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Hifonics Brutus BX 1505D Car Audio Amplifier Logo
227 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
