Question about Seagate (ST3160827AS) 160 GB Hard Drive
Seagate Barracuda 160GB hard drive
Drive is dead after only couple of years of very moderate home use. It was dying slowly, I managed to get all the data from it. Now it makes clicking noise for a while (when booting up) and then stops. Is there any way to fix it? I would try anything and appreciate any suggestions.
    Guru:
  • 120 Answers
Hard Drives are spun by powerful magnets. Over time the polarity of the magnet can degrade, causing the disc to wobble and generally be unreadable by the laser. IF you are very skilled in disc repair you can replace the internal components of the drive. You must understand though a single piece of dust will render a portion of the disc unreadable. If you don't know what you are doing, do not attempt to take apart the drive. Lots of techs in the computer repair industry call that noise you are hearing the click of death. You're better off replacing the drive than taking it apart and purchasing new internals for it. It's simply not worth it. FYI, I've had hard drives die after a single week of use, there are also hard drives that were made 15 years ago that still work fine. In recent months it's been proven that almost all mechanical hard drive failures happen due to magnets losing polarity on a microscopic level. Newer hard drives in years to come will likely be made to combat this, but thats still a while away.
Posted on Aug 15, 2007
SOURCE:
My Seagate Barracuda 7200.10 320 GB SATA Hard Drive is less than 2 years old and has crashed, any fixes?
Hard drives are only designed to last 3 to 5 years. Most hard drive manufacturers only warranty them for 1 year.
For whatever reason yours has died.
Backing up your data is imperative.
If you need to recover data from this hard drive, there are places online that you can send the drive to and they can recover the data on your hard drive. This can cost you a bundle though. If the data is not necessary, all you can do is buy a new one and reinstall your operating system.
Nov 28, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I require a driver for a seagate barracuda 7200.7 160GB hard drive
Seagate and Maxtor-brand External Hard Drives
External drives contain a standard computer hard drive in an enclosure that makes it possible to connect it to in of your computers external data ports (USB, FireWire or eSATA). This makes it easy to add a drive for backup or data storage to any computer with a compatible external data port.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">external hard drives
do not require additional drivers to function in Windows Vista
Microsoft Vista is the successor to Windows XP operating system. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows Vista
, Windows XP
Microsoft Windows XP is the successor to Windows 2000. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows XP
, Windows 2000
Microsoft Windows 2000 is the successor to Windows Me.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows 2000
, or Mac OS X
Mac OS X is the operating system that is produced by and comes standard on Apple computers.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Mac OS X
. These external drives are supported by the standard device drivers that are already included in these operating systems out of the box. Installing Serial ATA drives requires the installation of drivers from the Serial ATA motherboard. Click here for more information on this subject.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201413&NewLang=en
Oct 25, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What to do with unreadable but recognised hard disk segate 400GB
After data is recovered, it should be moved to another drive to keep safe. The drive that was recovered has to be reformatted and checked for errors before storing more data.
Nov 28, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
I have a problem .i.e my seagate barracuda 160gb HDD is not detecting in bios .it is a new HDD
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
Nov 14, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Open Questions:
See all Seagate (ST3160827AS) 160 GB Hard Drive Questions
Seagate (ST3160827AS) 160 GB Hard Drive Logo
192 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
