Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printhead ink cartidge replacement
Followed prompts on screen to change printhead ink cartidge (k) black & yellow. It will not recognise that I have change the cartidge and is still asking me to change it. Tried switching off and starting again, but the same happens every time. Can you help please.
    Sergeant:
  • 390 Answers
Ok, you may have blocked printheads. Remove cartridges, using a cleaning solution and cotton buds (q-tips) thoroughly clean all residue. Now replace cartridges and try again.
Posted on Aug 16, 2007
SOURCE:
HP Deskjet 5940 won't recognise new black ink cartridge
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
Dec 30, 2013 | HP Deskjet 5940 Photo InkJet Printer
Indicator says "Printhead Problem". The
You do not say what your make and model is. So follow the screen prompt and replace the black/yellow print head.
Jul 04, 2011 | Office Equipment & Supplies
My office jet L7590 printer suddenly quit on me. It keeps playing a message that says the printhead has a problem
Did you let one of your inks run dry? If so, you need to replace the effected printhead. This model has two, one for black and yellow, and a second for cyan and magenta. If you let the yellow run dry but have tons of black, it still effects the black/yellow printhead. Same with the other, either color going dry makes its printhead go bad. Either printhead will set you back about $75. Easy to remove and replace once you get the new printhead.
Bottom line with this model of printer...DON'T let you inks run dry. A new ink cartridge is $20 vs. $75 for a new printhead.
FYI - This is the most common mistake/problem with this printer. The Inkheads are built to last at least 40,000 prints. That's several years for most of us, that is unless you let the inks run dry.
Feb 09, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Istalled new ink cartidges in a Kodak ESP5 and color is faded and Black and white in not even there ??
issue is with printhead.
Try re-installing the ink cartridge....clean printhead from Menu > Maintenance > Clean printhead.
Else, visit www.kodak.com/go/itg and follow the steps to order a free printhead for you.
Or
call 18004216699 and get a printhead free of charge
Jan 24, 2010 | Kodak ESP 5 Printer
New kodak esp5250
Try to clean the printhead
Press Home > Maintenance > Clean printhead
If still the same issue
Visit www.kodak.com/go/itg
IF still same issue call or chat with tech support and get the printhead replaced free of charge
Jan 03, 2010 | Kodak ESP 5 Printer
The printer keeps saying there is a problem with the printerhead with the black/yellow. what can i do to fix this problem. The black yellow cartridge still have some ink in it. do i need to just change the...
Unfortunately, it sounds like you need a new printhead C9381A. You can hope that it's clogged from lack of use and go into printer properties and attempt to clean it (it will use a lot of ink in the process). However, the the black/yellow printhead generally wears out faster than the C9382A cyan/magenta printhead. Replacement should cost around $70 for each.
Oct 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
The printer is not recognising cyan ink cartidge CLI-BC even though it is full
Try doing a nozzle check to see which colors are getting through the printhead. If you are missing lines in the pattern or there is no ink color showing, you will have to do a head cleaning. Was your printer out of ink for any length of time? If so, it is a clogged printhead. some printers are designed in a way that will not allow you to print at all, if you are out of a color. They do this for a specific reason- If you were allowed to print in black and you were out of yellow and you did this for a month and then replaced the yellow, you would have a clogged printhead. Why? Because there is a reservoir in the print head and if you do not replace the ink, after a while, the ink in the reservoir will dry out and you will have a clogged printhead. The only way to fix this is to do a head cleaning (2-3-4, depending on how bad the clog is) and that uses a lot of ink. So, Epson does not allow you to print if one color is out, to save you the time and expense of having to do a head cleaning.
Did you remember to take the tape off the top of the cartridge? If so, run a few cleanings and do a nozzle check. If there is still no cyan, your print heads may be clogged
Aug 05, 2008 | Canon Office Equipment & Supplies
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
217 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
