Question about RCA Lyra RD2215 MP3 Player
Error i turn it on and it says rca first than it says please wait then in like a second it turns off
It usually corrects itself in 1hour or so i used to have the same problem
Posted on Nov 30, 2007
SOURCE:
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
I TURN ON MY MP3 PLAYER AND IT FREEZES ON PLEASE WAIT SCREEN PLEASE HELP
I TURN ON MY MP3 Problem with the RCA M4208 MP3 Player I TURN ON MY MP3 PLAYER AND IT FREEZES ON PLEASE WAIT SCREEN PLEASE HELP
Jan 22, 2011 | RCA M4208 MP3 Player
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
Boot error...please wait
1 Hold down the power button for 15 seconds.
2 plug into usb on pc.
3 Update the firmware
http://www.rcaaudiovideo.com/categories.aspx?product=317&post=4
Good luck. Worked great on mine.
Dec 30, 2008 | RCA M4204 MP3 Player
RCA D770 dont know how to program--lost manual
Check this link to Wiki,
http://wiki.answers.com/Q/How_do_you_program_an_RCA_d770_universal_remote_if_you_don't_have_a_code_search_button
http://download.ethomson.com/english/RCA/ACCESSORIES/IB/D770.pdf
I had trouble with the ethompson link
Turn on device.
Press and hold the button for device you want to program ( TV etc),
press the on/off button and hold until the LED turns on, and then release both buttons.
Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off.
When the device turns off, stop pressing play.
Press REVERSE, wait two seconds and continue doing this until the device turns back on.
To finish programming, press and hold STOP until the LED turns off.
Jun 02, 2008 | RCA D770 Remote Control
RCA OPAL M4002A ERROR MESSAGE
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 02, 2008 | RCA OPAL M4001 MP3 Player
56 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
