Currently have 512 Mb RAM and want to max it out. When I try to watch a streaming video file, my computer overheats/fan turns on and computer shuts down.
Based on what I've read, there are two memory slots expandable to 2,048Mb. I presume the current configuration is: in one slot there is a 512Mb, or does it have two 256Mbs one in each slot? ____________
If I replace the current 512Mb w/two 1Gb RAM (one in each slot), will this configuration also cause my computer to overheat?
Any advice in how it all works would be much appreciated. Thanks
If those are the correct specs for your computer, you can indeed install two 1 Gb sticks in it. The overheating may be caused by a ventilation issue on the laptop. There is an access door on the bottom of the laptop that is held in place with a Phillips head screw, you can remove the panel and see if there are two sticks installed. .
Sure! You need to buy the correct RAM that's for your laptop. Turn off and unplug it. Remove the old RAM and install the new RAM exactly like you removed the old RAM. You can now replace the access door and boot the laptop back up. It isn't difficult, just take your time. You can always go to PC Pitstop and they have a test that checks all your components. Post back if you need anymore help!! Good luck!
