Question about Brother MFC-1970MC Plain Paper Inkjet Fax
MFC-1970MC Check Paper error
I left much too many sheets sitting in the received area of my My 1970MC, and I'm assuming that last week when it tried to print its weekly report, it jammed because the slot was blocked. Now it displays a constant Check Paper error. I've checked absolutely every area and there's no errant paper. I've used compressed air to clear out any dust bunnies or paper snips, but nothing helps so far. Any ideas?
  • 328 Answers
The black sensor flags have to move freely. Usually one gets dislodged when paper jams are removed to forcefully.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 16, 2007
SOURCE:
Remove roll from sheet path how
This is one of frequent error in this series.
as you know two types of media paths 1. roll media 2. Sheet media. In sheeteet media loading area, you can observe 'u' shaped(extremly right side where sheet media sits) plastic mould which paper passes through in it. This palstic mould contains paper sensor to sence the sheetmedia. If this sensor is dusty, printer will treats that sheet path accupied by media. The best method to clean this sensor is to blow pressure air in this sheet path area.bicycle pump is best for this process.. try it...
Jan 31, 2014 | HEWLETT-PACKARD T790 InkJet Plotter...
Print error
Remove print head/cartridge and reseat.
Nov 20, 2013 | Brother MFC-1970MC Plain Paper Inkjet Fax
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
MFC640 Printer had a paper jam I took the paper out from the back put the cover back on its still flashing paper jam. what should I do?
TRY OPENING AND INSPECTING ALL AREAS WHERE THE PAPER GOES. USE A TORCH OR BRIGHT LIGHT TO CHECK IF THERE ANY BITS OF PAPER. ALSO CHECK IF ANY BITS MISSING FROM THE JAMBED SHEET OF PAPER. LOOK FOR A SMALL PIECE OF PAPER. AROUND THE ROLLERS OR PAPER MOVEMENT AREA. .ALSO IF PRINT HEAD IS ON LEFT SIDE GENTLY MOVE IT TO THE CENTRE WITHOUT TOUCHING ANYTHING, AND CHECK FOR ANY PAPER BITS BEHIND THE PRINT HEAD..
TO DO THIS YOU MUST REMOVE THE PAPER JAM COVER AT REAR OF MACHINE, LIFT UP THE WHOLE SCANNER COVER AND INSPECT. WHEN COMPLETE REPLACE THE REAR COVER AND CLOSE THE MACHINE. THEN RETRY.
HOPE THIS HELPS BARRY UBON.
May 08, 2011 | Brother MFC-640CW All-In-One InkJet...
I need to fax using magic jack
it won't help even if you could. Magic Jack is digital, ALL fax machines are ANALOG devices
Jul 06, 2010 | Brother MFC-1970MC Plain Paper Inkjet Fax
How do I connect?
You can use the Windows NT4 drivers located at http://www.brother.com/E-ftp/info/mfc/mfc970mc.html. Most likely you will need a parallel printer cable (D25 Male to C36 Male).
Feb 14, 2009 | Brother MFC-1970MC Plain Paper Inkjet Fax
I Lost my memory...
Make a copy of something, then you'll know for sure.
Dec 18, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
Line almost straight down center when receiving fax
if you try a internal print such as a report does it go away? if so its more lucky the person sending you the fax.
if you print a report and its on there i would check the ribbon and look for marks, also it could be a transfer problem causing these marks.
Hope this gives you a starts
Oct 21, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
How to replace fax paper
User manual (PDF) can be downloaded from here.
Good Luck!
Mar 26, 2007 | Brother MFC 1970MC All-In-One InkJet...
Brother MFC-1970MC Plain Paper Inkjet Fax Logo
151 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
