Question about Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
Hi, I will give the best description possible here. About a week ago my Maytag Performa Clothes Washer went nuts. I put in the load of laundry and walked away as usual to let it start filliing and what not. Except this time it didn't stop filling. The agitator process never started so I turned it off and put it on spin and it drained the what and spun the clothes just like normal. And Tried it a couple of times and the same thing the water just fills and never stops and the agitator won't start. But spin works normal. Any Ideas? I would be very Greatful thanks. Aaron Walden.
  • 19 Answers
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Posted on Aug 16, 2007
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 07, 2010 | Washing Machines
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
A serious transmission problem, I doubt that it is worth the cost of repair, sorry.
Aug 21, 2017 | Maytag Performa PAV2200
Agitator noise in maytag performa machine
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
Dec 03, 2008 | Maytag Performa PAV2200
Washing Machines Logo
711 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
