Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60"projection TV The top right side and bottom left side of my TV are discolored. Is this something I can try and fix myself?
    Genius:
  • 1,153 Answers
Convergence ic's are about to go! Look for loose connection on board first and if no loose conn. Replace IC's these are the big IC's STK-392-***. And there are also resistors along side them that has to be changed also. check for blown fuse too! IN same area.
Posted on Sep 05, 2007
SOURCE:
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Feb 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi 60sdx88b
i will try to help you on that one too as soon as I can get a repair case history on that particular model.
Jan 27, 2009 | Hitachi 60SDX88B 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email [email protected] as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Feb 25, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at [email protected] as to your conclusion in case it will help others. thanks, Adam
Oct 10, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
