Question about Epson Stylus Photo R300 InkJet Printer
Text Size of Copies
Not sure if this is a computer problem or a printer problem! When I highlight text and go to print the copies come out in much smaller text size than the originals. Everything used to be fine up to a couple of months ago. Is there a setting I can alter somewhere?
    Sergeant:
  • 390 Answers
Yes, check your printers settings under fonts, and choosed a deafult print type that you like, and size.
Posted on Aug 16, 2007
  • Geraldine Watts Aug 25, 2007
    If this does not solely correct the issue, you can try going to printer properties and check the restore default settings box.
Xp 225 want to print 15 copies but its giving blank page in between each copy ?
remove or shorten header and footer. look at print preview and adjust font if text exceeds page size. make sure page size is correct.
Sep 13, 2017 | In Office Equipment & Supplies
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
Normal printing is ok but the copies are to light
Change your copy settings from Text/Photo to Text. This will enable perfect 1 to 1 copies.
Oct 02, 2010 | Lexmark X646e All-In-One Laser Printer
My printer keeps repeating old subjects, and the print is very small... new inkjets are in.. Nothing else to add... I can't get it to print from my computer... the copies are ok.
I'm not sure I understand what you mean by "repeating old subjects", but that sounds like a printer queue issue. Try the following, and test printing after each step.
  1. Reset the printer. (instructions here)
  2. Print a self-test report. (here)
  3. Clear the print queue (see here)
As far as the size of the print, you will need to adjust this setting in the application you are printing from...In other words, you have to change the size of the text in the original document.
If you're printing from an IE browser, check the File>page setup options and make sure your haven't checked shrink-to-fit. Otherwise, use the File>Print Preview command to monitor the size of text in the printed material. In the browser, zoom adjustment affects the printed output.
On the other hand in Word, etc, you'll need to Format the font size in the document to change the printed text to a larger size.
(The zoom level adjustment only affects your view of the document at hand).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 12, 2009 | HP Deskjet F340 All-In-One Printer
I am making a copy of an article on my computer.
If you are copying from an internet source, file copy the document to your computer. Next step is,
go to your document settings or adjust the font size by highlighting all the text in your document. set to desired font size you want most probably you need 16-18 in size. save it.
Jun 22, 2009 | Cannon i70 Printer
Printed font size too small
Most web browsers have an option to change the text size on the page you are viewing. In IE8 it is accessible through the Page menu, Text Size. It defaults to Medium, and there are 2 smaller sizes and 2 larger sizes available.
May 29, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Print size has changed to very small off internet
Assuming that normal printing is fine, This is due to the size of the print in the email. To output larger print you'll have to copy the email into a document, change the size and then print the document.
Apr 30, 2009 | Dell 924 All-in-One InkJet Printer
Printer will not Print Black Ink copies
try to clean and allign the catridges from the front panel menu of the printer..
regards,  raj_p5983
Jan 11, 2009 | HP Photosmart C5280 Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
