Question about JVC AV-27230 27" TV
UNLOCKING THE FRONT LOCK CONTROL
I do not have the orginal remote I accidently pushed the button on the front of the TV that LOCKS the front contols. How do I unlock the FRONT LOCK CONTROLS. Yikes Help
Hold it in and it will change. mike
Posted on Sep 24, 2007
SOURCE:
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
I accidentaly turned the FPA lock on my TruFlat RCA tv and the original remote broke. i just bought a RCA universal remote from best buy. now how do i get rid of the lock?
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
OK.
Aug 24, 2011 | RCA TruFlat 27F520T 27" TV
My channels were scanning them selves and now the tv is locked and i dont have the right remote for it
Hello
Without orginal remote control, it will be very difficult to unlock your RCA tv. If you can gather a original remote from your friends or realatives who own the same model of tv, just borrow from them and try the following methods. One amoung them will surely unlock your RCA.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. OK.
Apr 18, 2011 | RCA TruFlat 27F520T 27" TV
Seem like tv as lock on. rca tube flat screen
Hello
To unlock your RCA tv do the following. One amoung the method decrbed here will surely unlock your TV. I thinks that you have its orginal remote control with you.
Mar 04, 2011 | RCA TruFlat 27F520T 27" TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
2004 Camry front driver door lock will only lock/unlock with key, the remote and lock button locks and unlock all locks fine except for the front driver side door lock. You have to either use the key or...
Remove the door panel and reconnect the plug going to the front driver door lock or, if you can hear the motor trying to engage the door lock cam when you press the lock/unlock remotereconnect the door lock lever bar
Jun 09, 2009 | 2004 Toyota Camry
Lock Button on Coby TV FlatScreen
try to see the manual of that tv or try to ask help of tecnicians thanksss and hope to help you
Jan 21, 2009 | Toshiba 42H81 42" Rear Projection...
VR3845
On the remote, just above the red "REC" button is a button marked "LOCK". Hit this button and it will unlock the panel. I have hit this button accidently several times.
Oct 31, 2007 | GoVideo VR3845 DVD Recorder/VCR
JVC AV-27230 27" TV Logo
169 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
