Question about GE 31GT740 31" TV
Guide Plus issue...
I have my TV hooked up to satelitte so I don't need the guide plus at all. I don't want to to come on automatically when I turn the TV on. Is there anyway to stop it from doing this??
Yep ... just figured this out myself today. When the Guide screen is up, navigate thru the options to Setup. Then select Review Options. You then get to a screen that gives you the option to turn of the system auto display. Good luck!
Posted on Aug 17, 2007
Gemstar Guide Plus TV Guide popup
1) Reset the code go www. fitness.manualsonline. com or www. remotecodelist.com and downlod for free
2) Try again and proof.
3) If the problem persist you must go to the repair shop TV for fix it
God bless you
Jun 14, 2012 | Directv RC32 Remote Control
Whenever I have an outage or disconnect the tv, guide plus needs to be downloaded again. How do I eliminate that problem of guide plus? I now have a cable box from Comcast that connects from cable from...
Sharp TV, Guide Plus Download problem
Solved by using Sharp TV Remote: Set Up, Guide Plus, Enter 00000 (zip code),
No more Guide Plus downloading!
Jan 02, 2010 | Sharp 36K-X2000 TV
How can I turn off guide plus so it doesn't come on everytime I turn on the TV? I think This is the model#
Hi my name is Eric,
I can help you with your issue ,
Using the original remote enter quide plus menu , under setup tab look for general and set the default to off.
like a little on/off switch it turns off the guide plus
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 06, 2009 | Proscan PS36700 36" TV
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Guide-Plus feature pops up
GO INTO THE GUIDE PLUS SET UP AND WHERE THE ZIP CODE IS PUT IN ALL ZEROS.
Aug 18, 2009 | Televison & Video
Have Warning message on DVD 'Your Guide Plus has not received TV Listings. Check your host channel.' What do I do?
Symptoms / Customer Description
TV Guide issues.
Example:
1. Not getting the correct info, or no information.
2. TV Guide giving double channels.
3. TV Guide grid comes up but no information.
[Primary Symptom Code: 118X ]
Solution
TV Guide information comes from the Host Station.
1. If no information on some channels or incorrect information not TV issue, but station not giving any information or incorrect information.
2. If grid comes up, but no TV Guide Info could be
siginal issue.
3. Double stations showing up. Unfortunately double listing is the way it's going to be. They have to send out all possible OTA listings for the area. You can hide the channels that you are not getting.
For these type of issues
Please have the customer call our Customer Support Line 800-222-7669
Our Call Center Rep. will fill out an investigation form with data pulled from the TV. These reports will be sent to Gem Star for their investigation, and the Call Center will get
back to the customer.
Apr 14, 2009 | Televison & Video
Guide Plus crashing
This problem is possibly a failure on you digital main pcb. Hoping its not hardware, best thing is to try to totally reset the guide plus. Go into the guide plus menu and find the setting to reset or restart setup. If this does not solve you issue, try hard booting the tv (unplug for 2 minutes) and try again. In quite a few cases, the manufacturer of the tv will have a software upgrade that may fix guide plus issues. Contact your manufacturer for that information
Dec 07, 2008 | Televison & Video
GE 31GT740 TV problem
hit the clear button on the remote and it will clear the guide plus off the screen
Jul 09, 2008 | GE 31GT740 31" TV
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
GE 31GT740 31" TV Logo
151 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
