Question about Technics SL-BD22 Turntable
Drive belt has come off.
The drive belt on my Technics SL-BD22 has come completely off, how can I put it back on?
Ok.Thats a difficult part to explain on a pick up.So listen up and give attention.Take off the plate of your driver and adjust the belt from the down side of your plate where there is a circle.put it in there and grab the belt to one side and adjust it to the "turner"then put your vinyl and play it.
Posted on Aug 23, 2007
SOURCE:
What size belt on the SL-Bd22
Just purchased a belt for my SL-BD22 from Vintage Audo (Audio?). The belt size is 23.6 X .180 X .025 inches. Their part number for this belt is:B00926DJ74. Hope this helps.
Oct 21, 2012 | Technics SL-BD22 Turntable
How do i install a belt on technics turntable sl-bd22
If you remove the rubber pad, you should be able to grasp the metal table. A gentle tap onto the center spindle while pulling up on the table should release the table. Place the new belt onto the underside of the table. Replace the table onto the spindle. Then feed the belt over the motor hub.
Dan
Apr 20, 2011 | Technics SL-BD22 Turntable
My belt on the turntable has fell apart to old I guess can I purcase a new one?
Replacement drive belts are easily available on the internet - try Amazon or E-Bay and search by turntable make and model number.
Feb 09, 2011 | Technics SL-BD22 Turntable
Drive belt on my SL-BD22 turntable broke. Where can I get one locally near Wilmington, NC?
I can't help you with where you can get one locally but I have a tip on FixYa which tells you where to get the belt and how to install it. It is located at http://www.fixya.com/support/r4123810-change_belt_most_turntables Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Technics SL-BD22 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
High pitched singing
It could be the wrong drive belt if the turntable is of the old fashioned type and does'nt have the direct drive. If the 33/45 switch isn't working properly then its a possibility its the drive belt tension on the turntable.
Apr 11, 2009 | Technics SL-BD22 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
Drive Belt - Technics SLBD22 turntable
Try http://www.vintage-electronics.net/ttbelt.html
Jun 16, 2007 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
191 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
