Question about Sony Handycam DCR-PC330E Mini DV Digital Camcorder
No image (LCD and viewfinder)
After at least two years, I turn the cam on, great picture, but I had to charge the battery. So I switch it off and charge the battery. After charging, I turn it on again: no picture. Menu is working (so LCD is working), no viewfinder. Made a recording: no image, but there is sound. What is wrong?
  • ccsoleil Sep 15, 2007
    I will contact the nearest dealer and ask if they can help me with this, here known as, european model... Thanks.
  • 169 Answers
First check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company...:-)
Posted on Sep 07, 2007
SOURCE:
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
No picture on LCD monitor when camera (rebel xt) is turned on
I am not sure what is the problem. You say no"picture"..is the screen totally black? Even when you try to preview photos in your camera memory? If so there is a problem with the hardware, LCD screen battery, or some other part.
If you mean you only see numbers and photo setting information on the LCD, that is normal for this Rebel models. The picture only appears in the viewfinder. It does not have a "live view' function to switch the image from the viewfinder to the LCD while you are shooting, as later model have. I have such a model and it is very disappointing.
Please rate Fixya Answers.
Apr 29, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
LCD SCREEN
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
Mar 11, 2008 | Fuji FinePix A345 Digital Camera
Kodak C643 Screen black
One way out of the glare is to use the optical viewfinder (if your camera has one) to preview your image instead of the LCD. Another possibility is to buy a camera that has a backlit LCD.
Mar 09, 2008 | Kodak EasyShare C643 Digital Camera
Sony DVD92 LCD/Viewfinder doesn't display image
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Dec 17, 2007 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-PC330E Mini DV Digital Camcorder Logo
85 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
