Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
55" No volume
Had volume last time i watched tv but now i turn it on and it is just dead silence checked evey connection still no volume
    Scholar:
  • 173 Answers
See if u can plug a headset jack in the front somewhere. some remotes have a funtion that turn the speakers off on the projector so u can hook up external speakers in the back of set. check that. also try switching to mono mode only. if all fails you need a shop. good luck
Posted on Aug 17, 2007
Why do the TV speakers not silence when the headphone port is used?
Headphone socket connection fault. Not cuts off the internal speaker. Replace the socket with an identical one.
Electro help
Aug 19, 2014 | Hitachi Televison & Video
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Starter wont engage
Could be the switch, the solenoid, or the starter. You would need to check for power at the starter post each time the key switch is in the start position. You can hook up a test light or a meter to watch it.
Jul 08, 2013 | Ford Mustang Cars & Trucks
My fujitsu plasmavision has no volume
check to see if the Mute is on..
you may need to call in a technician , in the box itself is a small amp that powers the speakers. This seems to have gone bad in yours and needs replacing.
simply look at the speakers and you will see it connected to a small circuit board , that's the amp circuit.
Dec 30, 2012 | Fujitsu P55XHA40US 55 in. Plasma...
Turn on TV and it stays on channel 6 for 1 minute.
the problem probably on the corroded channel and volume switch tri to clean the switch with a contact cleaner...you can buy it on the electrical/electronic store...also check for any corossion at the system ic on yhe main board. there are two big ic on the mainboard one is the jungle ic or chroma and the other one is the system ic which is feets are directly connected to the channel/volume switches
clean the in between of the feets/terminal of the ic.and this will solve the problem
May 20, 2010 | Philips Magnavox TP3285C 32" TV
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
