FixYa.com
Tags:
Eclipse SIR-ECL1 SIRIUS Radio Receiver
Antenna hookup 2007 dodge ram (by 3 users)
posted by Nockrnoll on Aug 15, 2007
Is there an adapter that will utilize the factory sirius antenna already installed in my factory radio in a 2007 dodge ram 1500? So I don't have to have the antenna stick on my dash like the GPS is?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by dothedew88, posted on Jan 06, 2008
see my post below
Comment by cmapes, posted on Jan 03, 2008
I have a 2006 Dodge 3500 4x4 truck. It has the factory radio and satellite antenna mounted at the center rear of the cab. I listen to Sirius radio all the time with no problems except for when I put on my overhead camper. Then the signal becomes intermittent. Is there a way to relocate the factory antenna or add an auxiliary antenna to alleviate this problem?
Best Solution
posted on Aug 19, 2007
Thanks for Trying (70)
imseth85
Rank:Wiz Wiz
Rating: 84%, 31 votes
First test to see if you really do have a factory Sirius antenna. The dealer will tell you the car is Sirius ready, but that does not mean you have the antenna. Your radio should have a "SAT" button on it....pushing it should bring up the Sirius emergency weather station, which will play even if your sirius isn't activated. If pushing the "SAT" button does not do this, then you simply have a "Sirius Ready" factory radio, and no factory Antenna and/or tuner. In this case, my advice would be to either mount a sirius antenna on the roof and get a starmate or something, or go to Dodge and spend upwards of $700 for the factory sirius antenna and tuner. If you car does have a factory sirius antenna....then just call 888-539-7474, and activate the sirius that is already in the car, no need to add anything. Hope this helps or at least clears things up.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 06, 2007
Not Rated (0)
dothedew88
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Brian Webb brianrwebb@ca.rr.com will make you a cable that will hook up to the end of your factory connector at the tuner. Just email him and tell him your vehicle and what length cable you need. I have a 07 also that I've done. If you would like pics email me mikebradyjr@yahoo.com Good luck
Sorry. You need JavaScript activated to use this Flash animation.
Solution #3
posted on Nov 20, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
cut it up No problem
Can you Help with these Satellite Radio Receivers problems?
how
how do i set/tune radio... Answer This...
Titles
radio works but tile like... Answer This...
http://www.viewsatusa.com/VS200...
how to get code for receiver... Answer This...
Sirius Anttena
I have a 2007 dodge ram 1500... Answer This...
How to intall to Eclispse...
Has nayone out there installed... Answer This...
Repair Service
Find Satellite Rad. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
