Question about Canon HS-1200TS Calculator
Exponents:how to use my calculator
I have no idea how to get my calculator to show exponents
  • 4 more comments
  • Anonymous Nov 04, 2007
    how can my calculator show exponents
  • Anonymous Nov 09, 2007
    i don know how toget the exponents
  • Anonymous Nov 13, 2007
    i type a 3 EE 2 and get 300. wanting to get 9. what's up with that?
  • Anonymous Apr 07, 2008
    exponent of 2.2540
  • timrox247 Nov 19, 2008
    how do you do it?
  • Anonymous Feb 09, 2009
    where is the exponet button on the caculator?
$18,000 = PV(1+ 0.0537/12)60
Posted on Oct 09, 2008
I need to know what the one place is to 3^99
Posted on Apr 30, 2008
4 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: How to use negative exponents on a calculator?
your calculator will never allow you to enter a negative exponent. so heres what you do.Any negative exponent of a number can be reversed and turned into a fraction for example 4^-1=1/4 or 8^-2=2/8=0.25. Hope this helps.
Posted on Sep 21, 2009
  • 8081 Answers
SOURCE: how to set double digit
To enter powers of 10 you use the [EE] key.
EX: 1.07 x10^(38) type in 1.07[EE]38 [=]
Posted on Aug 31, 2010
  • 102366 Answers
SOURCE: I have a TI-30X II S calculator. How do you
Use the ^ key, located above and left of the 7 key. For example, to calculate 2 raised to the 120 power, press 2 ^ 1 2 0 =
Posted on Jul 23, 2011
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
Jan 26, 2016 | Casio ClassPad 300 Calculator
NOT SHOWING NEGATIVE EXPONENTS
Try this if you have parenthesis.
(5*10^-9)*(4,4*10-9).
I'm assuming you are using a comma as the decimal deliminator and are located in Europe. (4,4 instead of the English 4.4).
Your working example also has no spaces between the elements of yoyr formula. Watch this.
Apr 05, 2014 | Texas Instruments TI-83 Plus Calculator
I cannot get the answer in decimal format. I have tried everything in the manual, and also online suggestions. Here's an example: Evaluate: (.2) with exponent of 4... the answer should be .0016,...
In the default NORM1 display mode, values whose magnitude are less than 0.01 are automatically displayed in scientific notation.
Press SHIFT MODE 8 2 to select the NORM2 display mode. In this mode, the calculator does not switch to scientific notation until the magnitude drops below 0.000000001 .
This is all described in the "Calculation Modes and Calculator Setup" section of the manual, beginning on page E-7.
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
How do i get the exponent 4.695 x 10 to the power of 23
Type 4.695 [EXP] 23. It does not show the "10" in the display, but the two smaller digits to the right shall be read as exponents to base 10.
Jan 25, 2011 | Casio FX-250HC Calculator
I have a student who just got a new calculator (TI-84). when you press the exponent button (x2) or the carrot button the numbers following the exponent stay superscripted. How do I adjust it so she can...
There's nothing wrong, the calculator just has the newest version of the operating system. To tell the calculator you're finished entering the exponent, simply press the right-arrow. If you don't want the new MathPrint mode, press MODE, press up-arrow to get to the second page, keep pressing up-arrow to get to the top line, highlight CLASSIC, press ENTER, then press 2ND [QUIT]. Now the calculator will display as the older operating system did.
The new MathPrint mode shows exponents, roots, fractions, and other things more like they appear in textbooks.
Nov 23, 2010 | Texas Instruments TI-30XA Calculator
My exponent key does not revert to regular script after i'm done with the exponent. it stays as superscript.
Press the right-arrow key to tell the calculator you're done with the exponent. Otherwise the calculator thinks you're typing in a very complicated exponent.
Nov 16, 2010 | Texas Instruments TI-84 Plus Calculator
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
Sep 20, 2009 | Texas Instruments TI-83 Plus Calculator
To solve 10 raised -3, to be done with cal., answer in the display ought to be .001
The calculator has several decimal display formats: FIX, SCI, NORM and ENG.
Here are examples of calculations with different formats and how to set them.
It may be a good idea for a user to get accustomed to the scientific display format, because it is the one most calculators adopt when the result to be displayed is too large or too small--when there are not enough places on the screen to display the result.
To help you with the power of 10 notation
1 billion =1000 000 000 =1 E 09 (9 zeros after 1 >> exponent 9)
1 million=1 000 000 = 1 E 06 (6 zeros after 1 >> exponent 6
1 thousand= 1000 =1 E03 (3 zeros after 1 >> exponent 3)
One= 1 = 1 E0
One tenth = 1/10 =0.1: the 1 is ONE position after the decimal mark>> exponent -01
One hundredth =1/100 =0.01 the 1 occupies the 2ND position to the right of the decimal point, exponent -02
etc.
1/1000 =0.001 = 1E-03
1/10000=0.0001=1E-04 (1 in 4th position to the right of decimal mark)
1/1000000=0.000001 = 1E-06 (1 in 6th position to the right of decimal mark)
1E-09 =0.000000001 : the 1 is in the 9th position to the right of decimal mark.
Jul 24, 2009 | Casio FX-260 Calculator
Adding Exponents on a Casio fx-300MS
The calculator applies the rules during the internal calculations. But all it shows you is the (final) result. It does not keep track of what exponents you used to get to the result. It is not capable of doing symbolic manipulations.
Hope you are not too disappointed.
Apr 22, 2009 | Casio FX-300MS Calculator
Negative answer when squaring a neg number
You must put all negative numbers in Parenthesis otherwise your calculator is not squaring the negative .
Apr 20, 2008 | Texas Instruments TI-85 Calculator
Canon HS-1200TS Calculator Logo
1,180 people viewed this question
Clive
Clive
old marine
old marine
Ekse
