Question about Magellan GPS 315 GPS Receiver
Magellan 315 won't find satellites.
However, once in a while it will. But if I move the unit even a foot, I lose the satellites. I have it out in the open on a post. My rev. is 3.07 I think, not 3.15. Would up grading the rev help? How do I do that? I have tryed reitalizing SEVERAL times. Am about to give up.. HELP!!!
  • Tinkerone Jul 08, 2008
    My Magellan 315 also would lose the sattelites. This continued to get worse until now it will not get the sattelites at all. Has any one resolved this problem.
  • Anonymous Nov 11, 2008
    I had the same problem recently. Re-initializing the unit solved it.
I have one of these units and it too is experiencing the same problem. I have talked to one geocacher and he thinks it could be the connection to the antennae that is now broken. He has a different Magellan unit and he had to fix the antennae connection. I was going to try that on my unit, but I need to figure out how to open it. Hopefully this helps. If I find out more I will let you know. Greg
Posted on Sep 10, 2007
SOURCE:
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
Uppon "swich-on", my magellan gps 315 does not
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 23, 2011 | Magellan GPS 315 GPS Receiver
Hi I have a Magellan 320 that I have owned for 7 yrs. Due to the purchase of a chart plotter I have not used the 320 for about 2/3 years. Having switched it on this week the unit failed to gain a fix to...
I believe you have to input your location lat & long so that it knows basically where it is so that it can decide which sat's to use. Hope this may help.
NOW - CAN YOU HELP ME?
I have bought a 2nd hand 320 and want to upgrade to software V 3.15
I see you've done this with yours - can you tell me how to do it and send the s/w, please? Regards, Ron. Kerikeri NZ
Jan 18, 2011 | Magellan 12, 310, 315, 320
I have a Magellan 315 gps that is appoximately 10 yrs. old. Does it have an internal battery that needs to be replaced?
Not a fix, shared information.
Yes these units have an internal ten year lithium battery. I am currently researching this issue, as I have two dead and one working 300series GPSs. When the internal battery dies and the regular batteries are removed or die the unit will loose all user data (way points and routes), as well as the satellite map and initialization. After dieing the unit will appear to function normally but fail to lock on, track or get a fix. Only showing the coordinates from the initialization. These units also have an internal capacitor that provides sufficient power to hold the memory during quick battery changes, but not over night. I have as yet found a working solution, but only researching this for a few days.
barang at asia period com
Nov 19, 2010 | Magellan GPS 300 GPS Receiver
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
AM LOOKING FOR A MANUAL FOR MAGELLAN GPS 315
(magellangps.com/support/product.asp?prodid=2)
You can use this link to download manual.
Apr 24, 2010 | Magellan GPS 315 GPS Receiver
Was given GPS 315 found manuel.Do not know age of unit[old].Wil not lock satilites.
There may be a few reasons for it not locking on
'1) batteries too low
2) Sirf chip damaged
3) Not in an area where it has a clear view of the open sky
4) electricasl interference from other electronic products
5) High voltage power lines overhead
Manual here
https://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Please rate our service to keep the service online
Aug 16, 2009 | Magellan GPS 315 GPS Receiver
Case cracking Magellan 315
The only method I have found is with a dremmel tool and cut it open along the original split line.
All the electronics are clear of the case mid line. The case is a bit less than 3mm thick.
The antenna is closest with maybe a 2 mm clearance all round and the various (6) rear conector wires (on the right looking from the back) have a similar clearance but sit below and away when the unit is assembled. Cheers
Dec 16, 2007 | Magellan GPS 315 GPS Receiver
Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
Magellan GPS 315 GPS Receiver Logo
729 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
