Question about Pioneer Car Audio & Video
Pioneer CDX-FM1259 error
"Error A0" is displayed on the Pioneer Head Unit. This occurs mostly when the car is running but also will occur in "accessory" or with the key in the "on" positiion. I have had the unit since 2000 and it might be getting old, if I need to replace it which unit will use the same magazine so I can at least use the extra magazines that I currently own? Thanks
SOURCE: Problem with stuck magazine....
OK I have had exactly the same problem and spent the last hour or so fixing it. It seems to have its logical knickers in a twist after the battery going flat and won't eject because its left a CD in the playing position, IE, out of the magazine. So, remove the changer from the car (usually velcro then pull off the two phono and the power connectors) and undo the four small cross head screws holding the case on. Pull the front panel off (you may need to pinch the case in the middle top and/or bottom as there is a clip here holding the front panel), then either pull the sides of the case out until the two rotary Horizontal/vertical mount controls disengage (or you may be able to rotate them anti-clockwise until they pop off, but I didn't try this) and lift off the lid. Next, pull the four little mounting posts on the internal deck assembly out of their four rubber mounts on the outer case, and disengage the two springs from the horizontal/vertical mounting controls. The mech is now loose inside the case but be careful as its attached by a rather delicate ribbon cable to the outside cables and connectors, This will unplug after you pull off the sticky tape holding it to the chassis, but you might be able to do the rest of this without unplugging it if you turn the mech over carefully. You will see a motor assembly and several white cogs (actually you will see two but the little tiny one with a worm (spiral) drive only moved the CD mech optical head so ignore that one). Using a small screwdriver, carefully rotate the cog closest to the motor so that (viewed with the motor closest to you and to the right) the plastic parts under this assembly start to slide to the right. You should actually be able to see the CD underneath start to move to the laft, back into the magazine, and the CD mech will open up to release it. Once the cog doesnt want to turn any further (and the CD is completely back in the Mag), then you will be able to manually eject the mag by pulling sideways gently on a round white part on the mag side. The mechanism should click and release the mag. Hey presto... fixed. Now just reassemble the whole thing back into its case, probably a good idea to check that each of the CD's is correctly seated in the mag and that there is nothing wrong with any of them that could cause it to jam again, then go try it in the car prior to final assembly. As we now know that this unit seems to be prone to throw a wobbly if its power is removed with a CD in it, I would strongly recommend that you eject the mag before disconnecting the unit for final assembly, assuming it all works OK now, or indeed any time you might have to disconnect the car battery for any other reason. Hope this helps, it did it for me! Mark
Posted on Jan 21, 2007
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
SOURCE: pioneer 10 disc changer magazine stuck
i would like to be of assistance but i need to know the which pioneer 10 disc changer it is. send me the information and i may be able to help. thanks
Posted on Nov 26, 2007
SOURCE: DMR-EX75 error U81
I had this problem when first bought player, and as you checked on forums which suggested software error and said get replacement. Took to approved repairer who had it on test bed for 2 weeks with no problems. Brought it home connected it up and since then (6 months) no error codes. Think my problem was caused by connecting cable to AV1 rather than AV2 as I have now (HDMI cable to television) but could just be a coincidence. Probably a bit simplistsic and you may have already tried this but thought worth mentioning anyway - good luck!
Posted on Jan 08, 2008
  • 44 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
My pioneer cdx fm1259 will not turn on again after disconnecting battery
Try pressing the reset button (very small) next to the eject button on the changer with a sewing needle or anything else that has a narrow point.
Mar 05, 2017 | Pioneer Car Audio & Video
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
A0 error canyou fix it?
If you really enjoy the head unit call pioneer, there customer service is great and before you fork out another $300 for a new unit why not hear what they have to offer. Some companies have refurbed units ready to ship, just an option.
Aug 14, 2009 | Pioneer DEH-P7500MP CD Player
I have a CDX-FM65 Pioneer 6 disc player. The
I have a pioneer universal multi-cd system cdx fm65, the remote indicator unit display will not come on when you masn the handheld remote what do I need to do?
Jun 28, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Dec 05, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Pioneer Car CD Changer CDX FM673 Error Message
can anyone tell me were to get a installation manaual for a pioneer cd changer (cdx-fm67)
Apr 04, 2008 | Pioneer CDX-FM673 6-Disc CD Changer
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Car Audio & Video Logo
79 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
