Question about Fedders X Chassis A6X05F2B Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
When I plug my Fedders A6X05F2B air conditioner in it just beeps twice but doesn't turn on. The outlet I am getting power from runs my vacuum and anything else I plug into it though. Any ideas? thanks, Jim.
  • 1 more comment
  • jimbohhi Aug 20, 2007
    I got it working, but not sure how... I took the covers off, pulled out the control panel check all of the connections and still had the same problem. The response I got from the manufacturer was that I may need a new control panel (no other information). I let it set for a few days and tried plugging it in every other day to see if it would work (to no avail).
    Then today, I decided to remove it as it was doing me no good and letting cool air leak out of the house. I decided to try one more time and while holding the ground wire on the casing and pushing the on/off button on the control panel something happened and it turned on!!!! Maybe something on the back of the control panel rubbed on the metal frame or something? That was about an hour ago and I have not turned it off in fear that it may not start again. Good Luck!
  • Anonymous May 28, 2008
    my fedders is doing the exact same thing. However, i havent been able to plug it in to an actual wall outlet, only a power source and an extension cord.. Are the two beeps when you plug it in a diagnostic warning to plug it in to the wall? someone not as lame-braned as me please help!
  • Anonymous Apr 29, 2009
    Cleaned the air conditioning unit. Plugged into a regular grounded (two-prongs with ground prong) outlet.
    Unit gives two short beeps, and then does not turn on.
    Wish to get this fixed, but would rather buy new one if doing random things is only likely to get it fixed.
    New Friend:
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Posted on Jun 27, 2014
4 Suggested Answers
SOURCE:
  • 23 Answers
SOURCE: how do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Posted on Jun 17, 2009
SOURCE: Fedders a/c model #A6X05F2B. Just posted a
GO TO WWW.FEDDERS.COM AND DOWNLOAD IT U NEED TO HAVE ADOBE 9
Posted on Jun 30, 2009
  • 116 Answers
SOURCE: My Fedders plug in AC will not start. Is there a
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Posted on Aug 04, 2009
My window unit is leaking alot of water in my house
clean the filter . make certain its tilted ot the outsid eby about 1 inch. let me know if htis does not solve it or if it does thank you jon
Jul 25, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
MY AC UNIT WILL RUN COLD AIR FOR 2 MIN THEN IT WILL KICK OUT WITH ONLY THE FAN RUNNING. wAIT 3 MIN IT WILL KICK BACK ON FOR 2 MIN THEN STOPS AGAIN. WHAT DO I DO TO FIX THIS PROBLEM?
Clean the outdoor coil, slide the unit out of the case, take a garden hose and nozzle to it use a solid stream of water, and watch the fins that you do not damage them with the water. Clean the indoor coils as well, and check to see if the motor is oilable. Keep the water out of the other components.
Jul 08, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders a6xo5f2b-0j leaks inside even though its tilted out?
I have a fedders a6x05f2b and the compresser comes on but the fan does not. What can I do?
Jun 28, 2010 | Fedders AED24E7F Wall/Window Air...
Model a6q10f2a beeps 2 times when plugged in, and
Pull the unit from the wall and it`s shell,check the fan to see if it is turning ok by hand,if there is any restriction,it will blow the control board,the circuit board behind the controls,clean the unit while you have it out,if the fan is stiff,and does not turn,this could be the problem,and if so,the circuit board is most likely shot.Also,the circuit board is most likely shot anyway,even if the fan is fine,there is a lot of problems with fedders and other brands,and the circuit boards,they dont last too long.
Jun 11, 2010 | Fedders A6Q10F2B Q Chassis Room Air...
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
How do i add freon to fedders model # A6X05F2B
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
No power
Probably blew out the thermistat and the compressor, along with the the capacitor. Probably not worth the repair. good Luck
Jun 13, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders X Chassis A6X05F2B Air Conditioner Logo
2,720 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
