Question about Kenmore 63074 Top Freezer Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
Our fridge has stopped working. We have checked the coils to make sure they are clear of dust/debris...fine, we've checked the thermostat -- fine, we have checked the fan -- working appropriatly. What is strange is our freezer is fine...staying at 0 degrees or lower. Our fridge won't cool lower than 61 F...and this is the coolest setting. We suspect the compressor. Any thoughts?
  • Da Gunny Mar 30, 2008
    Freezer is staying pretty cool up top but the ice maker in freezer is not making ice as well below is warm and not getting cool. Hear the compressor running and sounds normal.
  • Anonymous Sep 14, 2008
    Yes, I have the same problem!
Failure to stay cold
Posted on Jul 23, 2008
    Novelist:
    Champion:
  • 244 Answers
Could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Posted on Aug 15, 2007
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer works fidge dont
Some fridges only cool the freezer, there is an evaporator fan motor that then blows are from the freezer into the fridge to cool it. You may need to replace the fan. ($30) It usually starts squealing before it goes. The fan is located in the freezer section probably at the top behind a vented cover. Check to make sure it spins very freely in not replace it. It could be your drain is plugged or frozen, pull out the fridge and look at the bottom to see where the hose enters the fridge, pour some hot water down from inside the fridge to see if it is clear if not, clear the hose.
Nov 01, 2009 | Dometic RM2852 Refrigerator
Freezer gets 10 below 0 and fridge is 60 degrees
Check and clean the condensor coils. Make sure the air ducts are free f frost and not blocked by anything. Make sure the light is turning off when the door is closed.
Eric
Sep 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
Jul 03, 2009 | Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Kenmore 63074 Top Freezer Refrigerator Logo
801 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
