Question about Canon P23-DH Calculator
Loading paper First time user. Cannot load the paper. Have tried all suggestions to date. Nothing works. Paper does not advance even though machine is trying to do so. Paper goes through slot at rear of calculator but will not advance into the printing area. Help!!
  • 17 more comments
  • Anonymous Nov 18, 2007
    paper won't print or feed
  • Anonymous Dec 03, 2007
    can not seem to place paper and make it feed
  • SHE7054 Feb 11, 2008
    CANNOT LOAD PAPER
  • Anonymous Mar 03, 2008
    can not feed paper thru back of printer
  • Anonymous Mar 08, 2008
    how do you feed new tape
  • Anonymous Apr 14, 2008
    cannot load paper. will not advance into any slot.
  • Anonymous May 02, 2008
    CANNOT LOAD PAPER INTO THE CALCUL;ATOR
  • cayers1979 May 09, 2008
    Can't get paper to feed please help!!!
  • Fuls May 20, 2008
    same prob
  • Anonymous Jun 20, 2008
    we have a canon p23-dhv calculator can not load paper need pictures
  • tdetrich Jul 09, 2008
    I cannot get the paper to advance. There are no instructions. It looks like there are paper guides on each side but it also looks like there is no where for the paper to advance. Could the product have been put together wrong?
  • annie2572003 Jul 31, 2008
    I cannot load the paper
  • Anonymous Nov 30, 2008
    The paper will not feed when loading paper...even if I press the feed button.
  • smileysonya Dec 05, 2008
    Same problem, the feed button won't work and there is an E on the display screen. Please advise
  • Anonymous Dec 07, 2008
    how do I load the paper?
  • AssignMeOne Feb 10, 2009
    I can't get the paper to feed through..HELP..
  • Anonymous Mar 16, 2009
    Cannot get new roll of paper to feed into machine
  • Anonymous Mar 23, 2009
    The paper won't feed! That was the whole draw for buying this model. If the paper doesn't feed, the attraction is eliminated and I might just as well use a hand-held calculator! Surely there must be SOME fix action!
  • Kamurphy86 Mar 28, 2009
    I bought this brand new. And the whole point was to print out recipes to my Renters. and What is the point of having it if i cant load the paper. This is very annoying and if you ever figure this out let me know at my E:mail Kandyapples22@yahoo.com
    Thank you
    Katie.
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Posted on May 14, 2009
I find folding the paper back on itself so it is square gives the rollers more to grab. You can also "push" the paper a little because it is stiffer.
Posted on Mar 30, 2009
I needed to remember what I tell my students, "read all the info at least TWICE" ie- feed the paper in the slot at the BACK of the calculator, and after it catches, it will work it's way out of the TOP slot. Thanks and GBYA
Posted on Jan 28, 2009
  • 28 Answers
A lot of times, the paper will not advance into the calculator without the paper being cut STRAIGHT ACROSS. Try cutting it straight across and then try to feed it in. The rollers should be able to grab the paper at that time.
If this helps, please rate me. Thanks, Patty
Posted on Jan 04, 2008
I tried the "cutting it straight across thing", no dice. The best thing to do is turn the paper into an air plane, and jam and feed!!!! Make sure you are putting it into the back slot first and foremost!!
Posted on Sep 24, 2008
2 Suggested Answers
SOURCE:
SOURCE: Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Posted on Jan 23, 2009
I can not get the paper to feed in my Unisonic XL-1149 calculator
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
Mar 01, 2018 | The Office Equipment & Supplies
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper loading error
hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Jul 22, 2009 | Epson Stylus Pro 9800 InkJet Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
How do you load paper into the printing calculator?
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Jun 20, 2008 | Canon P23-DHV Calculator
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Canon P23-DH Calculator Logo
1,380 people viewed this question
Clive
Clive
old marine
old marine
