Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Lg 50px4d The problem is there was a loud popping sound then the picture was dull and was still working as normal but its too dark to watch. could you help with this fault please. what parts are needed to fix?. thank you dupe
Sounds like the problem with 50" zenith plasma tv's which use the same screen, see:
http://www.avsforum.com/avs-vb/showthread.php?t=599668&page=45
Posted on Nov 27, 2007
Did it sound like a venetian blind being snapped?
Posted on Oct 10, 2007
Try reseting the defalt seting do not turn the trebl up it has hydef speackers if trebl is up it will pop
Posted on Sep 09, 2007
Ho to fix Lg plasma tv no picture or sound
Could be sudden power supply failure
May 13, 2016 | LG 60PA5500
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
42" LG plasma tv, 4
Probably filter capacitor in power supply if it
exploded should be easy to find may have caused other problems however
could be worth checking
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a LG plasma 42PC1DG, watching tv loud pop then no picture but still have sound, left tv unplugged for a while still no picture?
probably the pop was a fuse blowing inside that only controls the lamp should be an easy fix but open the tv at your own risk
Dec 06, 2010 | LG 42PC1D 42 in. Plasma Television
No picture after loud pop. Sound works fine
i have the same fault loud pop and no picture but sound is ok
Oct 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have A LG 50PX4D TV the display has gone off
Most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If its under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | LG 42LC2D 42 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Keeps blowing up
Sounds like a factory issue. You should call lG directly and explain it to them. They're likely to get you another unit.
Geno
Mar 10, 2008 | LG 50PX4D 50 in. Plasma Television
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lg 50px4d pdp tv
This is a very common problem with model. This problem is your Z sus Board. NOT your power supply, or Y sus board. There is a pair of Diode that goes bad. Your only solution is to change your Z sus Board. Part Number 6871QZH036B average cost $237.00
Best regards
Circuitcity
Jul 15, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
164 people viewed this question
Steve Allison
Steve Allison
