Question about LG WM0642H
Mold Smell in front loading LG Tromm
We are on our second washer and are experiencing the mold smell again. I have heard that you need to keep a front load washer open, but I know my brother has the same and does not do that. Our clothes smell like mold if we leave them in there for even just 5 minutes after the cycle is done. I have done a bleach cycle with the hottest water, but within a few day it is back. The last time water leaked into the casing of the machine and mold was there. HELP!!!!
  • Anonymous Nov 04, 2007
    Water accumulates in the rubber gasket just inside the door. I wiped mine with paper towels and took out a lot of nasty black residue - lessened the smell a bit but I'm sure water is accumulating in the bottom of the washer as well. Even after completely drying the detergent drawer and the gasket, if I close the washer door it becomes rainy with condensation in a few days!
  • 641 Answers
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Posted on Aug 15, 2007
SOURCE:
LG tromm mold smell.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps...
Daniel
Sep 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My machine has such a strong smell when the door is left open that is goes thru my whole house. I have black mold in the rubber ring - my machine is only 2 yrs old. Is LG helping their consumers?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Nov 09, 2009 | LG WM2688HWM TROMM SteamWasher
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Build up of black "gook"
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Aug 20, 2007 | LG WM-2277HW Front Load Washer
LG WM0642H Logo
733 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
