Question about Toshiba 57H81 57" Rear Projection Television
Zenith rear projection television
2 years old tv. 50" rear projection.Question. it is possible to change the projection unit for a new hdtv model? please advice. thank you claods miami, fl
    Scholar:
  • 173 Answers
No there are many diffent things. for your set has about 480 viewing lines or resolution where as hdtv has twice that. impossible to match it but you can take a hdtv signal and convert it work on your older set. good luck
Posted on Aug 17, 2007
SOURCE:
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Zenith projection tv convergence proublems
YOU HAVE BAD CONVERGENCE IC'S AND POSSIBLY SOME LOW OHMAGE RESISTORS THAT FEED THE IC'S.
Sep 14, 2009 | Zenith R40W46 40" Rear Projection...
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith M52W56LCD blue spot in center of screen
It could be as simple as dust contamination in the LE or lcd chip. You need a clean room to work on this area of the unit and NOTHING you can do there would make that possible, short of spending a few thousand to build one. Before we added a clean room enviroment we simply pulled the LE and sent it in to PTS - who has one and reinstalled...
In your case take it to a qualified shop and you'll save yourself a lot of grief..
Bill
Nov 19, 2007 | Zenith D52WLCD 52" Rear Projection...
Zenith blue corners
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Sep 02, 2007 | Zenith D60WLCD 60" Rear Projection...
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Blur
Most likely a unit this age with start showing signs of weak crts. These crt's hava a life of 7 to 10 years and your discription is failing crts. I am afraid it is time to move to a new unit.
Dec 25, 2006 | Zenith D60WLCD 60" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
