I just purchase a Canon DW 100, I follow the instructions, to attach the Canon vixia G21. I place the DVD - R disc in the DVD burner, it seem was burning DVD. When I played the DVD on a regular Dvd player, says disc error.
My name is Rosy, please I need your help
Thank you
Comments:
Mar 19, 2009
- how can I finalized in the settings, can you explain how, please
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD
Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving
your files in their native format than for creating standard DVDs that
can be played on regular DVD players. Regular (standard-definition) DVD players
can't play AVCHD, although many Blu-Ray players can. Unless you use a
Blu-Ray player that supports AVCHD playback, there are two solutions to
your problem:
1. If you want to keep your recordings high-def,
you can view them by playing them back with the DW-100, which must be
connected to your camcorder via the USB cable, then from your camcorder
to your TV via an HDMI cable.
2. If you want to have standard
DVDs that you can play on any DVD player, either import the files to
your computer and convert them to standard-definition using
video-editing software, then burn them to DVD with your computer's DVD
burner, or connect the analog output (component=better, composite=good)
to a stand-alone DVD recorder (i.e. not the DW-100).
I've used
the route of Vixia HF-10 camcorder > composite output > Panasonic
DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good
results when I've wanted to give videos to relatives who don't have
Blu-Ray players. You just have to make sure to set the camcorder 's
analog (composite) output to 480i so that it formats the picture in the
right aspect ratio, or else the 16:9 image will be squeezed to 4:3
instead of letterboxed.
Can the DW 100 burn non-AVCHD DVDs?? If not then I can only burn a HD DVD from my HG 20 and only...
(More)
Can the DW 100 burn non-AVCHD DVDs?? If not then I can only burn a HD DVD from my HG 20 and only people with Blueray DVD players can use them...
After going through the instruction manual steps to burn a DVD on the CANON DVD burner DW-100 my...
(More)
After going through the instruction manual steps to burn a DVD on the CANON DVD burner DW-100 my CANON HG10 camcorder displays error message "connect the compact power adapter" and the USB connection display in the top right corner flashes. I re-read the instruction and everything appears to have loaded (system update disc 1.0.1.0) correctly, anyone know what the problem could be?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
