Question about Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum
Hoover s3330 with something loose
Hoover s3330 Something is loose inside motor compartment. Trying to open case, 4 screws in the front are already out, but case still doesn't open. Where are remaining screws? Thanks.
  • 1673 Answers
SOURCE: Hoover vacuum handle attaching screws
They are just a coarse thread(very coarse) about 3/4 in long, phillips head.
Posted on Jan 06, 2008
SOURCE: Filter queen 95X (1991)
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
Filter queen 95X (1991) Motor is noisy but still work fine.
Can there be a loose screw inside ? Can I open the motor and look inside ?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service 1-800-344-1840
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
SOURCE: how do you open hoover s3639???????
Take out all the tools out of the tools compartment. The screws are "hiding" under the tools.
Posted on Jul 29, 2008
  • 389 Answers
SOURCE: I have a small canister
I may be able to help, but would need to know what model your machine is. Re-post, giving as much detail as possible and we'll see...
Posted on Feb 07, 2009
  • 430 Answers
SOURCE: Hoover U6317-930 - Turbine Locked Up!
You will need to remove the hood as though changing the belt. Then best to detach the handle/ bag chamber with the black screw at the lower end in the center.
Lay the vac flat and you should see two clamps over the motor housing, one on either side. Undo the clamps and the motor will lift out. There will be four more screws holding the fan shroud onto the motor housing. Remove these and detach the fan end only. Installation is the reverse order. The fan itself will unscrew if replacing,just secure the motor shaft without damaging it.
Polish the motor shaft clean for a new belt, removing burned rubber. I use 600 grit wet/dry sandpaper or steel wool.
Any evidence of a damaged fan blade means a new fan is required.
While you're at it, unscrew the end caps on the brush roll and remove the hair and thread. Then reassemble so it spins freely when holding the end caps. Install a new genuine belt. It will be snug, use the brush to pull it into place.
When reassembling be sure to engage the carpet height control through the lid
If this helps please acknowledge. If not psot back with the next problem
Posted on Oct 04, 2009
  • 147 Answers
SOURCE: Where are screws located that access main motor
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Posted on Nov 08, 2010
0 characters
1 Points
How do I open the case on this hoover
If you cant figure out how to open it I wouldn't recommend you trying to rewire it, take it to a repair shop or ask your local friendly electrician.
Oct 19, 2014 | Vacuums
Hoover telios 1600 dismantling
Remove the 4 screws in the Dust Bag compartment.
Remove the Power button and Cord-rewind botton. This involves using a screwdriver or knife to open/undo a plastic clip located under the bittons near the gril in the top-centre-back of the hover.
When holding the clip back, slide the button towards the bottom of the hover (IE: away from the bag compartment) till it pops out (this can be fiddley).
This will then reveal 4 more screws (within the springs and near the grill).
Then prise the hover open to reveal the motor and power-switch.
Mar 25, 2012 | Vacuums
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
Just picked up this vacuum at a second hand store. Inside I can't figure out how to attach the bag - there doesn't seem to be anything for it to hook on to - I am wondering if a piece is missing.
I have uploaded a parts diagram for your vacuum model that you listed that your repair under, the Hoover model S3330 and S3332 below. It looks like the part diagrammed number 3, which is called the Bag Holder may be missing from your vacuum if you're not able to get the bag in. This is a part that we're able to get for you if you need to purchase it. Please just visit our website,, and use the contact us link if you need to order this part.
Hopefully that's all it needs, and you'll be good to go! Please feel free to request a clarification if you actually have a different model then this. The model may be found on the bottom or the back of the vacuum, and usually starts with a letter in front on Hoover models. If you found this helpful, please be so kind and rate the repair solution as helpful by clicking the thumbs up icons at the top of the page. I really hope this helped you, thanks again.
Parts Schematic For Hoover Model S3330 & S3332
Chris J.
Apr 07, 2010 | Hoover S3330 / S3332 Straight Suction...
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful:
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
Hoover U5750-900 just shuts off
I have a similar bagless model U5757-900 that is shutting off. I disassembled the unit, and what I found is that the motor front bearing had accumulated enough grime so that the bearing locked up. When this happened, the bearing outer shell spun in the plastic housing, causing it to soften, from friction heat. This allowed the motor shaft to become off center from the normal, centered axis of rotation. Once this happened, the rotor inside the motor began to rub against the stator, the fixed part of the motor inside. This loaded down the motor, causing excessive current draw, which caused the overheat switch to activate, shutting down the machine.
In your case, it might not be as bad as in my case.
Remove the dual-cannister dirt cup.
To find out, disassemble the unit lower section: on bottom, remove 4 screws around the rotating brush housing. Remove the brush cover, then remove the brush, then remove the belt. Remove the wide plastic housing behind the brush. Remove the two screws, from the bottom, that retain the upper hood. Remove the hood.
On the back, remove the two screws and hose retainer going from the base to the upright section. This releases the hose from the lower section.
Now press the tilt release, and lay back the upright section. Remove the four screws, two on each side, from the trunnion caps, where the upright section tilts on the lower section. Remove the trunion caps. Remove the upright section from the lower section.
Remove the headlight cover (2 screws).
From the back, remove the single screw retaining the bezel above the headlight area.
Slide the bezel upwards and remove.
Remove the four screws that retain the motor cover clamshell. One is from front, and other 3 from rear.
Open motor clamshell halves to expose motor.
Note orientation/position of the three wires on the motor, and remove those wires. Lift motor out.
To open the motor, gently tap the edges of the impeller housing (aluminum shell) on the edge of the shell, in the little gaps around the shell.
Using a 1/2" socket, remove the nut in the center of the impeller. This is a LEFT HAND NUT. TURN RIGHT TO LOOSEN IT.
Gently wiggle the impeller while pulling until impeller comes off of motor shaft. Use a glove so the impeller doesn't cut your hand.
Remove the large flat washer on the motor shaft. Remove the small sleeve from the motor shaft.
On the brush end of the motor, using a small screwdriver, pry out on the brush holders. Set them aside.
Remove the two screws holding motor together. Seperate the motor front from motor rear. Withdraw the motor rotating part.
Look into the inside of the stator, inspecting for bright, shiny areas where the rotor may be dragging on the stator. If you see these, then the front bearing, in the plastic motor frount, is fried. I don't think Hoover sells this part alone. Also inspect the plastic front bearing retainer to see if there is any melting that has allowed the bearing to become off center.
In any case, if there is scrubbed out places inside the stator, then the motor requires replacement, about $70 for the motor... You might be able to find an entire new vac for less... or, like me, find one on the side of the street where someone has tossed out a unit.
You may luck out and find that the impeller unit is just filled with some trash so air cannot get to the motor for cooling... or you may have a shot motor.
Jan 03, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover savvy motor problem
The problem is the lower roller assembly circuit board fried. It happened with mine as well. I tried to order a new circuit board from Hoover, but they get it third party and don't want the liability. This is very frustrating. I'm waiting for them to call me back.
Apr 07, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum Logo
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
