Question about HP Photosmart 2575 All-In-One InkJet Printer
Incorrect print cartridge error on HP 2575
I've just submitted a generic print cartridge into my HP Photosmart 2575 and I'm getting an error that an incorrect print cartridge is installed. Is there any way to override this and get the cartridge to work?
  • Anonymous Aug 31, 2008
    Same problem with an HP Deskjet 3940.
SOURCE:
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 51 Answers
SOURCE: INK CARTRIDGE PROBLEM Remove and check
Take the cartridge out and rub the contacts with a piece of damp tissue paper and try again.
Check the contacts in the printer itself where the cartridge sits. If there is any damage or pin hole on the white ribbon with the gold contacts on it then the printer is unrepairable but it sounds like a cartridge problem. Try changing the cartridge as well
Posted on Jun 14, 2008
SOURCE: Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Posted on Jul 06, 2008
  • 521 Answers
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Posted on Aug 14, 2008
rtrahan
  • 741 Answers
SOURCE: Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Posted on Dec 25, 2008
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Can you use 2 black cartridge instead of 1 black 1 colour in the HP all in one 2575 photosmart printer
You would not be able to.
The cartridge front is different and would not fit.
Also it is a requirement to have the correct cartridges to print.
Jan 11, 2011 | HP Photosmart 2575 All-In-One Printer,...
Don't have the cd to install my printer onto my new computer. HP 2575
go to hp site and go to support tab/ drivers download/printers/2575 and download the install file or birn it to a cd.
Oct 10, 2010 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Mar 21, 2010 | HP Photosmart 2575 All-In-One InkJet...
I get an Incorrect Cartridge messages, Gray Photo Print Cartridge inserted now is not intended for use in this printer.. It is a HP C4100 All in one printer, and it is a number 93 Tricolor cartridge....
Their is a couple of reasons for this,
If your not using HP branded print cartridges they could just be bad
if it is hp brand then try cleaning the cartridge as this error happens a lot when the ink gets stuck on the electronic parts of the cartridge (might have to replace)
You can always go to HP website for further help
here is a link
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=C4100&submit=Go+%BB
Apr 06, 2009 | HP Photosmart C4180 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
211 people viewed this question
Clive
Clive
Thomas F. Schneider
