Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 Having a problem at first with F-01 message now the door lock will not come on stopping the machine from working. LCD looks normal.
  • Arthur Paterson
    Arthur Paterson Aug 21, 2007
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
Posted on Jan 26, 2008
FO1 is a motor based faultcode, however door lock falt can only be caused by a faulty doorlock or pcb. Regards Advisor
Posted on Aug 22, 2007
Hotpoint wt940
the door is not locking , possibly caused by the interlock itself or motor brushes worn ( most likely if machine is a few years old at least ) could also be no power to lock via control board .
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima wt940 I load washing and set a normal program (say 40 degree wash). The door is firmly closed. I push start. Even though the LCD is on and I have pushed start - there is no...
'door' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultimat WT960 has F-01 flashing at me. What do I do to fix this and get my machine to work again?
heres what it says on the hotpoint site F01 - Short circuit motor triac which usually means you have to replace the control board you might want to call for a technicain if you are not able to make an electonic repair of this nature if you are able to make the repair you can find the part at marconeapplianceparts or allbrandsapplianceparts they will both be able to mail your part directly to you door. I hope this opinion has helped in your appliance situation please message me back if you have any futher questions also please remember to rank how this opinion has helped in your appliance situation.Thanks again
Nov 09, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error message f01
F-01 Motor triac short circuit this means that there is something wrong with the main board. but there is a thing to try 1st try unplugging the machine for 5 mins and plugging it back in and switch it on and try again. if it still dose not work after some attempts then it looks like you need to get the engineer out to fix it, hope this helps.
Nov 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima has stopped halfway through a wash and has the word door flashing.
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washingmachine WF860 comes with the message tESt
it's on test mode for the factory. this comes on if you hold the on and start buttons together. can be reset by turning on while holding both on until dOFF appears.
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
646 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
